SPA9000 + SPA8000
LufiGarrido
Hi:
Does anyone have the configuration for the SPA9000 to work together wirh the SPA8000 (as a PSTN gateway)?  I have a problem with the SPA3102 and need to access PSTN lines through an alternative, namely the SPA8000.  If there is another alternative, I would appreciate any input and experience.
Luis F. Garrido
nseto
Level 6
Level 6
You need to look at the SPA8800.  8800 has the 4 FXS and 4 FXO.  The SPA8000 has 8 FXS.
The first line of the SPA8800 would act exactly like the SPA3102, so you would configure that the same way.
Thanks for your clarification.
Would you happen tio have the configuration of both devices so that they can work together (SPA9000 + SPA8800)?  I have been having problems with the SPA3102 working with the SPA9000.
