08-27-2012 09:55 AM - edited 03-21-2019 06:12 AM
Hi:
Does anyone have the configuration for the SPA9000 to work together wirh the SPA8000 (as a PSTN gateway)? I have a problem with the SPA3102 and need to access PSTN lines through an alternative, namely the SPA8000. If there is another alternative, I would appreciate any input and experience.
Luis F. Garrido
08-29-2012 05:06 PM
You need to look at the SPA8800. 8800 has the 4 FXS and 4 FXO. The SPA8000 has 8 FXS.
The first line of the SPA8800 would act exactly like the SPA3102, so you would configure that the same way.
08-29-2012 05:16 PM
Thanks for your clarification.
Would you happen tio have the configuration of both devices so that they can work together (SPA9000 + SPA8800)? I have been having problems with the SPA3102 working with the SPA9000.
