SR520W
Linda.Azah
Please i dont understand what is wrong, i configured a default static route on my
SR520W router, it appears when u show running-config, but when u show ip route, its not on the routing table, please can someone help me? what am i doing thats incorrect?
Albert Wilhelm
Hello Linda,
Can you execute the following command?
Router# sh run | sec ip route
It should come back with the following:
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
If not, can you post the area where you defined the static route?
Hope this helps.
Bert Wilhelm
APW Solutions
Austin, TX
Hello Bert,
Thanks for ur answer, i issued the command
and yes it came out with that output, but when i issue the command show ip route, it says gateway of last resort is not set and on the routing table there is no default route still and i used the default configuration that came with the SR520W.
Hello Linda,
How is your customer's network connected to the internet? I am assuming you are using an ADSL or cable service but please confirm.
Other areas to troubleshoot:
1. Have you rebooted the modem in order to clear it's MAC address table?
2. Do you have the IP address of your Gateway? If so, I have configured the GW ip address in the IP route statement instead of the interface.
ROUTER_SR520#ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx (ip address of gateway)
3. Can you ping the gateway from the router?
If so, can you ping IP address outside the GW like the ISP's DNS server or google.com or other IP addresses?
Hope this helps.
Bert
