07-31-2012 07:12 PM - edited 03-21-2019 06:06 AM
People,
I checked this compatibility matrix at http://tools.cisco.com/ITDIT/vtgsca/VTGServlet and the 7902/7912/7940/7960 ip phones are not listed in release 8.6, does that mean they are not supported?, Has anyone made some test to verify this?
Solved! Go to Solution.
07-31-2012 07:36 PM
You can go to following location and open "Cisco Unified Communications Manager System Guide, Release 8.6(1)" document.
http://www.cisco.com/en/US/products/ps11369/prod_maintenance_guides_list.html
In this document , You can see the list of supported device Under Devices and Protocols we have Cisco Unified IP Phones
Ronak Patel
Rate helpful posts.
07-31-2012 07:36 PM
Ronak Patel
Rate helpful posts.
07-31-2012 08:33 PM
Excellent reference, thank you
