03-24-2015 01:22 AM - edited 03-21-2019 08:35 AM
Dear All,
My customer has installed an BE6K , but now the BE6K system status LED is Amber blinking. From the UCS C220 document , the amber blinking LED means the server is in a critical fault state, for example, boot failed, fatal CPU and/or bus error, over-temperature condition.
But i checked the temperature status LED, it is green, and the VCS which installed in BE6K , it works normally. so it seems the BE6K is normal.
So do anybody know about this issue, and how to troulbeshoot it?
Solved! Go to Solution.
03-24-2015 02:04 AM
you need to shut/power off the entire applications to configure CIMC and then, reboot UCS chassis
regds,
aman
03-24-2015 01:36 AM
you can login through CIMC to get more details for the cause.
regds,
aman
03-24-2015 01:45 AM
We didn't configure CIMC when we installed BE6K, so we need to reboot it to configure, but I don't know whether it will affect the VCS installed in the BE6K when rebooting.
03-24-2015 02:04 AM
regds,
aman
03-24-2015 02:13 AM
OK, thank you very much!
03-24-2015 02:20 AM
u are welcome.
regds,
aman
07-24-2015 12:01 PM
This discussion has been reposted from Additional Communities to the Business Edition 6000 community.
