Transferring Calls Directly to Voicemail with SPA525G
SPA52GUser
We want to transfer calls directly to voicemail without having the call ring at the extension. Does anyone know of a workaround? Please advise if I should post this in another spot.
Thanks.
mdobiac
Level 3
Level 3
Hello SPA52GUser,
Depending on your phone system if you have the option of configuring a dial plan using a prefix then the extension user to send the call directly to VM for the call routing.
Example the UC500 series used the prefix 6 then the extension of the user to call/transfer directly to a users VM.
Hope this helps,
Michael D.
If this post is helpful please rate or mark as correct.
mdobiac
Level 3
Level 3
Hello SPA52GUser,
Hope this helps,
Michael D.
