trunk-group on FXS ports: switch to next port if "no answere"
HOLGER HAHN
Beginner
Beginner
In one team of our company we have three fax machines which will be reached on four different extensions (175, 345, 375 and 385).
On a VG224 I've configured three FXS voice-ports and two dial-peers associating to a trunk-group:
trunk group PSC-Fax
hunt-scheme longest-idle
voice-port 2/0
trunk-group PSC-Fax
timeouts ringing 20
voice-port 2/1
trunk-group PSC-Fax
timeouts ringing 20
voice-port 2/2
trunk-group PSC-Fax
timeouts ringing 20
dial-peer voice 175 pots
trunkgroup PSC-Fax
destination-pattern 175
dial-peer voice 345 pots
trunkgroup PSC-Fax
destination-pattern3[478]5
It works fine!
But what if one fax machine doesn't answere?
Hunting should be go on to the next voice-port!
But it don't. After the ringing timer is expired the call will be disconnected.
How can I configure the gateway to achieve this?
Daniele Giordano
Collaborator
Collaborator
I'm not sure but try this in global configuration:
no voice hunt no-answer
That doesn't work because "voice hunt" commands are related to dialpeers.
And I want a hunting to the next voiceport within the trunk group...
HOLGER HAHN
Beginner
Beginner
In the meantime I opend a service request (616393915) with the result, that this is not possible with hunt group.
The gateway has to be controlled by a CallManager and than you can do it by a hunt pilot.
