UC-520 Voicemail Issues
dhyland
System was working without issues but now voicemail doesn't seem to be working.  Users call each other and their phones now just ring and never go to voicemail.  Was out on holiday when the issue started so my suspicion is that changes were made but I'm not seeing anything indicative of change...  Any initial thoughts of places to start looking?
Mailboxes are enabled with a nice chunk of minutes.   Voicemail enabled for all users.  Etc.
Much thanks for any ideas!
danplacek
Level 4
Level 4
1. 'call-forward noan' has been removed from your extensions.
or
2. IOS is having trouble establishing calls with CUE.
A copy of your running config (sensitive information removed) and a "debug ccsip messages" while making a call that should be going to voicemail would be great.
-Dan
Please rate useful posts.
7 Replies 7
danplacek
Level 4
Level 4
or
-Dan
It does appear that you were correct. Someone had set some lines for call-forwarding to anther extension while some of them the busy and noan options were removed completely... After adding them back into the config the extensions don't just ring any more but instead ring busy after the 20 seconds that I set up for noan...
Codec looks good (g711ulaw) but fast busy to voicemail persists.  Any ideas?
Like I said, a copy of your running config and/or a SIP trace would help a lot... otherwise we are just randomly guessing.
-Dan
Config as follows:
version 15.1
parser config cache interface
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname uc520-1
boot-start-marker
boot system flash:uc500-advipservicesk9-mz.124-20.T.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 8
logging buffered 4096
logging console critical
aaa new-model
aaa authentication login local_authen local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec local_author local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
crypto pki trustpoint TP-self-signed-2155555563
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2155555563
revocation-check none
crypto pki certificate chain TP-self-signed-2155555563
certificate self-signed 01
  30855549 308201B2 A0555201 02020101 300D0609 2A864886 F70D0101 04055550
  3155530 2D055555 04031326 4955532D 53555C66 2D536967 6E65642D 43657274
  69666963 6175552D 32313539 33323038 3635551E 170D3133 30343239 31353436
  35555517 0D355030 31555530 30305530 305A3031 312F302D 06035504 03155649
  4F555D53 656C662D 5355576E 65642D43 65727469 66696361 74652D32 31355533
dot11 syslog
no ip source-route
ip cef
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
no ip bootp server
no ip domain lookup
ip host mail.mail.com 192.168.1.254
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp feature access-code
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  bind control source-interface Vlan100
  bind media source-interface Vlan100
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class custom-cptone CCAleavetone
dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice class custom-cptone CCAjointone
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class cause-code 1
no-circuit
voice register global
max-dn 128
max-pool 32
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^6/ //
voice translation-rule 2001
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
license udi pid UC520-24U-8FXO-K9 sn xx
archive
log config
  logging enable
  logging size 600
  hidekeys
vtp version 2
username admin privilege 15 secret 5 xx
ip tcp synwait-time 10
ip tftp source-interface FastEthernet0/0
class-map match-any VoIP-Control-UnTrust
match access-group name VoIP-Control
class-map match-any VoIP-RTP-UnTrust
match protocol rtp audio
match access-group name VoIP-RTCP
class-map match-any VoIP-Remark
match ip dscp ef
match ip dscp cs3
match ip dscp af31
policy-map Policy-UnTrust
class VoIP-Remark
  set dscp default
class VoIP-Control-UnTrust
  set dscp af31
class VoIP-RTP-UnTrust
  set dscp ef
class class-default
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
crypto isakmp policy 10
hash md5
crypto isakmp key xx
crypto isakmp client configuration group VPNClient
key xxx
pool EZVPN_POOL_1
acl 150
crypto ipsec transform-set AES esp-aes esp-sha-hmac
crypto dynamic-map SDM_CMAP_1 99
set transform-set AES
reverse-route
crypto map clientmap client authentication list sdm_vpn_xauth_ml_1
crypto map clientmap isakmp authorization list sdm_vpn_group_ml_1
crypto map clientmap client configuration address respond
crypto map clientmap 1 ipsec-isakmp
set peer xx
match address 199
crypto map clientmap 10 ipsec-isakmp dynamic SDM_CMAP_1
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip nat inside
ip virtual-reassembly in
interface Loopback1
description *** used for GRE to site 2 ***
ip address 10.2.10.1 255.255.255.252
ip nat inside
interface Tunnel0
description *** GRE Tunnel to Site2 ***
bandwidth 1536
ip address 172.31.250.1 255.255.255.252
ip mtu 1420
ip nat inside
delay 4999
keepalive 10 3
tunnel source Loopback1
tunnel destination 10.2.11.1
tunnel path-mtu-discovery
service-policy output Policy-UnTrust
interface Null0
no ip unreachables
description $FW_OUTSIDE$
ip address xxxx 255.255.255.248
ip access-group Outside in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect SDM_LOW out
duplex auto
speed auto
crypto ipsec df-bit clear
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface Vlan1
no ip unreachables
ip nat inside
interface Vlan100
description *** Voice VLAN ***
ip address 10.1.1.1 255.255.255.0
no ip unreachables
no ip proxy-arp
ip nat inside
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.1.1
ip local pool EZVPN_POOL_1 192.168.20.2 192.168.20.10
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip nat inside source list 106 interface FastEthernet0/0 overload
ip nat inside source static 10.1.10.1 xx extendable
ip nat inside source static 10.1.10.2 xx extendable
ip nat inside source static tcp 192.168.1.254 25 xx 25 extendable
ip nat inside source static tcp 192.168.1.254 80 xx 80 extendable
ip nat inside source static tcp 192.168.1.254 443 xx 443 extendable
ip route 0.0.0.0 0.0.0.0 xx
ip route 10.1.2.0 255.255.255.0 172.31.250.2
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip route 10.1.11.0 255.255.255.252 172.31.250.2
ip route 192.168.11.0 255.255.255.0 172.31.250.2
ip route 192.168.12.0 255.255.255.0 172.31.250.2
ip access-list extended OutsideIn
remark *** BEGIN: xxxx ***
permit ip xxxx 0.0.0.63 any
permit ip xxxx 0.0.0.31 any
permit ip xxxx 0.0.0.7 any
permit ip host xxxx any
permit ip xxxx 0.0.0.15 any
remark *** END: xxxx ***
remark *
remark *** BEGIN: VPN ***
permit udp any any eq non500-isakmp
permit udp any any eq isakmp
permit esp any any
remark *** END: VPN ***
remark *
remark *** BEGIN: ping/traceroutes ***
permit icmp any any echo-reply
permit icmp any any time-exceeded
permit icmp any any unreachable
remark *** END: ping/traceroutes ***
ip access-list extended VoIP-Control
permit tcp any any eq 1720
permit tcp any any range 11000 11999
permit udp any any eq 2427
permit tcp any any eq 2428
permit tcp any any range 2000 2002
permit udp any any eq 1719
permit udp any any eq 5060
ip access-list extended VoIP-RTCP
permit udp any any range 16384 32767
logging esm config
logging trap debugging
access-list 106 deny   ip 192.168.1.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 106 deny   ip 192.168.1.0 0.0.0.255 10.1.11.0 0.0.0.255
access-list 106 deny   ip 192.168.1.0 0.0.0.255 10.1.2.0 0.0.0.255
access-list 106 deny   ip 192.168.1.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 106 deny   ip 10.2.10.0 0.0.0.3 10.2.11.0 0.0.0.3
access-list 106 deny   gre host 172.31.250.1 host 172.31.250.2
access-list 106 permit ip 192.168.1.0 0.0.0.255 any
access-list 106 deny   ip any any
access-list 150 permit ip 192.168.1.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 150 permit ip 10.1.1.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 150 permit ip 10.1.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 199 permit ip 10.1.1.0 0.0.0.255 10.1.2.0 0.0.0.255
access-list 199 permit ip 192.168.1.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 199 permit ip 192.168.1.0 0.0.0.255 10.1.2.0 0.0.0.255
access-list 199 permit ip 192.168.1.0 0.0.0.255 10.1.11.0 0.0.0.255
access-list 199 permit ip 10.1.1.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 199 permit ip 10.1.10.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 199 permit gre host 172.31.250.1 host 172.31.250.2
access-list 199 permit ip 10.2.10.0 0.0.0.3 10.2.11.0 0.0.0.3
access-list compiled reuse
tftp-server apps11.8-2-2TR2.sbn
tftp-server apps31.8-2-2TR2.sbn
tftp-server apps41.8-2-2TR2.sbn
tftp-server apps70.8-2-2TR2.sbn
tftp-server cmterm_7936.3-3-13-0.bin
tftp-server cnu11.8-2-2TR2.sbn
tftp-server cnu31.8-2-2TR2.sbn
tftp-server cnu41.8-2-2TR2.sbn
tftp-server cnu70.8-2-2TR2.sbn
tftp-server CP7902080002SCCP060817A.sbin
tftp-server cvm11sccp.8-2-2TR2.sbn
tftp-server cvm31sccp.8-2-2TR2.sbn
tftp-server cvm41sccp.8-2-2TR2.sbn
tftp-server cvm70sccp.8-2-2TR2.sbn
tftp-server dsp11.8-2-2TR2.sbn
tftp-server dsp31.8-2-2TR2.sbn
tftp-server dsp41.8-2-2TR2.sbn
tftp-server dsp70.8-2-2TR2.sbn
tftp-server jar11sccp.8-2-2TR2.sbn
tftp-server jar31sccp.8-2-2TR2.sbn
tftp-server jar41sccp.8-2-2TR2.sbn
tftp-server jar70sccp.8-2-2TR2.sbn
tftp-server P00308000500.bin
tftp-server P00308000500.loads
tftp-server P00308000500.sb2
tftp-server P00308000500.sbn
tftp-server S00105000200.sbn
tftp-server SCCP11.8-2-2SR2S.loads
tftp-server SCCP31.8-2-2SR2S.loads
tftp-server SCCP41.8-2-2SR2S.loads
tftp-server SCCP70.8-2-2SR2S.loads
tftp-server term06.default.loads
tftp-server term11.default.loads
tftp-server term31.default.loads
tftp-server term41.default.loads
tftp-server term61.default.loads
tftp-server term70.default.loads
tftp-server term71.default.loads
tftp-server flash:SCCP42.8-3-2S.loads
tftp-server flash:SCCP45.8-3-2S.loads
tftp-server flash:SCCP75.8-3-2S.loads
tftp-server flash:apps42.8-3-1-22.sbn
tftp-server flash:apps45.8-3-1-22.sbn
tftp-server flash:apps75.8-3-1-22.sbn
tftp-server flash:cnu42.8-3-1-22.sbn
tftp-server flash:cnu45.8-3-1-22.sbn
tftp-server flash:cnu75.8-3-1-22.sbn
tftp-server flash:cvm42sccp.8-3-1-22.sbn
tftp-server flash:cvm45sccp.8-3-1-22.sbn
tftp-server flash:cvm75sccp.8-3-1-22.sbn
tftp-server flash:dsp42.8-3-1-22.sbn
tftp-server flash:dsp45.8-3-1-22.sbn
tftp-server flash:dsp75.8-3-1-22.sbn
tftp-server flash:jar42sccp.8-3-1-22.sbn
tftp-server flash:jar45sccp.8-3-1-22.sbn
tftp-server flash:jar75sccp.8-3-1-22.sbn
tftp-server flash:term42.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:APPS-1.0.4.SBN
tftp-server flash:CP7921G-1.0.4.LOADS
tftp-server flash:GUI-1.0.4.SBN
tftp-server flash:SYS-1.0.4.SBN
tftp-server flash:TNUX-1.0.4.SBN
tftp-server flash:TNUXR-1.0.4.SBN
tftp-server flash:WLAN-1.0.4.SBN
tftp-server flash:cp524g-08-01-07.bin
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Chime.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Vibe.raw
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:CampusNight.png
tftp-server flash:CiscoFountain.png
tftp-server flash:Fountain.png
tftp-server flash:MorroRock.png
tftp-server flash:NantucketFlowers.png
tftp-server flash:TN-CampusNight.png
tftp-server flash:TN-CiscoFountain.png
tftp-server flash:TN-Fountain.png
tftp-server flash:TN-MorroRock.png
tftp-server flash:TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:RingList.xml
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:ATA030100SCCP040211A.zup
tftp-server flash:term75.default.loads
tftp-server flash:B016-1-0-3.SBN
tftp-server flash:apps75.8-4-1-23.sbn
tftp-server flash:cnu75.8-4-1-23.sbn
tftp-server flash:cvm75sccp.8-4-1-23.sbn
tftp-server flash:dsp75.8-4-1-23.sbn
tftp-server flash:jar75sccp.8-4-1-23.sbn
tftp-server flash:SCCP75.8-4-2S.loads
control-plane
voice-port 0/0/0
timeouts ringing infinity
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 210
description Configured by CCA 4 FXO-0/1/0-Custom
caller-id enable
voice-port 0/1/1
description Configured by CCA 4 FXO-0/1/1-Custom
caller-id enable
voice-port 0/1/2
description Configured by CCA 4 FXO-0/1/2-Custom
caller-id enable
voice-port 0/1/3
description Configured by CCA 4 FXO-0/1/3-Custom
caller-id enable
voice-port 0/3/0
description Configured by CCA 4 FXO-0/3/0-Custom
caller-id enable
voice-port 0/3/1
description Configured by CCA 4 FXO-0/3/1-Custom
caller-id enable
voice-port 0/3/2
description Configured by CCA 4 FXO-0/3/2-Custom
caller-id enable
voice-port 0/3/3
description Configured by CCA 4 FXO-0/3/3-Custom
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confprof1
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile- Using codec711
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 6
conference-join custom-cptone CCAjointone
conference-leave custom-cptone CCAleavetone
associate application SCCP
dial-peer cor custom
name internal
name local
name domestic
name international
name local-plus
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-domestic
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member domestic
member local-plus
member national
member national-plus
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-national
member national
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national-plus
dial-peer cor list call-toll-free
member toll-free
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 50.
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 500
b2bua
codec g711ulaw
no vad
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 150 pots
port 0/3/0
dial-peer voice 151 pots
port 0/3/1
dial-peer voice 152 pots
port 0/3/2
dial-peer voice 153 pots
port 0/3/3
dial-peer voice 200 voip
description interofficetransfers
destination-pattern 4..
session target ipv4:10.1.2.1
codec g711ulaw
no vad
dial-peer voice 57 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American*Local Number**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 6[2-9]......
forward-digits all
no sip-register
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American*Long Distance**
preference 5
destination-pattern 61[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American*International Number**
preference 5
destination-pattern 6011T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American*Emergency Number**
preference 5
destination-pattern 6911
forward-digits all
no sip-register
dial-peer voice 69 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup ALL_FXO
description **CCA*North American*Service Number**
preference 5
destination-pattern 6[2-9]11
forward-digits all
no sip-register
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
no dial-peer outbound status-check pots
sip-ua
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm tag 1 confprof1
conference hardware
video
max-ephones 32
max-dn 128
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 1 to 1 type bri
caller-id block code *916
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message xxxx
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 7914 S00105000200
load 7916-12 B016-1-0-3
load 7916-24 B016-1-0-3
load 7902 CP7902080002SCCP060817A
load 7906 SCCP11.8-2-2SR2S
load 7911 SCCP11.8-2-2SR2S
load 7921 CP7921G-1.0.4
load 7931 SCCP31.8-2-2SR2S
load 7936 cmterm_7936.3-3-13-0
load 7960-7940 P00308000500
load 7941 SCCP41.8-2-2SR2S
load 7941GE SCCP41.8-2-2SR2S
load 7942 SCCP42.8-3-2S
load 7945 SCCP45.8-3-2S
load 7961 SCCP41.8-2-2SR2S
load 7961GE SCCP41.8-2-2SR2S
load 7962 SCCP42.8-3-2S
load 7965 SCCP45.8-3-2S
load 7970 SCCP70.8-2-2SR2S
load 7971 SCCP70.8-2-2SR2S
load 7975 SCCP75.8-4-2S
load ata ATA030100SCCP040211A
load 521G-524G cp524g-08-01-07
time-zone 8
time-format 24
voicemail 501
max-conferences 8 gain -6
call-forward pattern .T
call-forward pattern 9.T
call-forward pattern 9.......
call-forward system redirecting-expanded
moh music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name admin secret 5 xx
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6.T
secondary-dialtone 6
create cnf-files version-stamp 7960 Apr 10 2013 10:45:46
ephone-template  15
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  1
number 101 no-reg primary
name IP-Paging1
paging ip 239.1.1.1 port 2000
ephone-dn  2  dual-line
number 219 no-reg primary
label Cameron 219
description Cameron
name Cameron
hold-alert 30 originator
ephone-dn  5  dual-line
number 291 no-reg primary
label After Hours Ring
description PhoneA Analog
name PhoneA Analog
ephone-dn  6  dual-line
number 292 no-reg primary
label 292
description PhoneB Analog
name PhoneB Analog
ephone-dn  7  dual-line
number 293 no-reg primary
label 293
description PhoneC Analog
name PhoneC Analog
ephone-dn  8  dual-line
number 294 no-reg primary
label 294
description PhoneD Analog
name PhoneD Analog
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  10  dual-line
number 222 no-reg primary
label Alan 222
description Alan 222
name AlanE
call-forward busy 501
call-forward noan 501 timeout 20
hold-alert 45 originator
ephone-dn  13  dual-line
number 220 no-reg primary
label Alan 220
description Alan
name Alan
ephone-dn  16  dual-line
number 216 no-reg primary
label Jesse 216
description Jesse
name Jesse
ephone-dn  23  dual-line
number 208 no-reg primary
label Daniel 208
description Daniel
name Daniel
call-forward busy 210
call-forward noan 210 timeout 30
ephone-dn  26  dual-line
number 213 no-reg primary
label Christopher 213
description Chris
name Christopher
ephone-dn  28  dual-line
number 215 no-reg primary
label RDPotter 215
description Robert
name Robert
ephone-dn  33  dual-line
number 221 no-reg primary
label Sarah 221
description Sarah
name Sarah
ephone-dn  51  dual-line
number 299
label After Hours
description *** After Hours Ring ***
name After Hours Ring
preference 1
huntstop channel
no huntstop
ephone-dn  52  dual-line
number 299
label After Hours
preference 2
huntstop channel
no huntstop
ephone-dn  53  dual-line
number 299
label After Hours
preference 3
huntstop channel
ephone-dn  76  octo-line
number 233 no-reg primary
label Ben 233
description Ben 233
name BDW
ephone-dn  77  dual-line
number 225 no-reg primary
label Randy Shop 225
description Randy Shop
name RandyR
ephone-dn  78  dual-line
number 217 no-reg primary
label 217
description Time Clock
name Time Clock
ephone-dn  79  dual-line
number 250 no-reg primary
label Conference
description Conference
name Conference Phone
hold-alert 15 originator
ephone-dn  80  octo-line
number 210 no-reg primary
label Bobbi 210
description Bobbi 210
name Bobbi
call-forward busy 203
call-forward noan 203 timeout 10
ephone-dn  81  dual-line
number 402 no-reg primary
label Kevin 402
description Kevin 402
name Kevin
ephone-dn  82  dual-line
number 403 no-reg primary
label Lucas 403
description Lucas 403
name Lucas
ephone-dn  83  dual-line
number 202 no-reg primary
label BEN 202
description BEN 202
name Ben
ephone-dn  84  dual-line
number 214 no-reg primary
label Ricky 214
description Ricky 214
name Rick
ephone-dn  85  dual-line
number 224 no-reg primary
label Jonathan 224
description Jonathan 224
name Jonathan
ephone-dn  86  dual-line
number 211 no-reg primary
label Delana 211
description Delana 211
name Delana
ephone-dn  87  octo-line
number 203 no-reg primary
label Cindy M 203
description Cindy M 203
name Cindy
call-forward busy 221
call-forward noan 221 timeout 10
ephone-dn  88  dual-line
number 205 no-reg primary
label Jeremy 205
description Jeremy 205
name Jeremy
ephone-dn  89  dual-line
number 207 no-reg primary
label Kent 207
description Kent 207
name Kent
call-forward noan 210 timeout 45
ephone-dn  90  octo-line
number 218 no-reg primary
label Randy 218
description Randy 218
name Randy
ephone-dn  91  dual-line
number C008 no-reg primary
conference ad-hoc
preference 3
ephone-dn  92  dual-line
conference ad-hoc
preference 2
no huntstop
ephone-dn  93  dual-line
conference ad-hoc
preference 1
no huntstop
ephone-dn  94  dual-line
conference ad-hoc
no huntstop
ephone-dn  95  dual-line
number C007 no-reg primary
conference ad-hoc
preference 3
ephone-dn  96  dual-line
conference ad-hoc
preference 2
no huntstop
ephone-dn  97  dual-line
conference ad-hoc
preference 1
no huntstop
ephone-dn  98  dual-line
conference ad-hoc
no huntstop
ephone-dn  99  dual-line
number C006 no-reg primary
conference ad-hoc
preference 3
ephone-dn  100  dual-line
conference ad-hoc
preference 2
no huntstop
ephone-dn  101  dual-line
conference ad-hoc
preference 1
no huntstop
ephone-dn  102  dual-line
conference ad-hoc
no huntstop
ephone-dn  103  dual-line
number C005 no-reg primary
conference ad-hoc
preference 3
ephone-dn  104  dual-line
conference ad-hoc
preference 2
no huntstop
ephone-dn  105  dual-line
conference ad-hoc
preference 1
no huntstop
ephone-dn  106  dual-line
conference ad-hoc
no huntstop
ephone-dn  107  dual-line
number C004 no-reg primary
conference ad-hoc
preference 3
ephone-dn  108  dual-line
conference ad-hoc
preference 2
no huntstop
ephone-dn  109  dual-line
conference ad-hoc
preference 1
no huntstop
ephone-dn  110  dual-line
conference ad-hoc
no huntstop
ephone-dn  111  dual-line
number C003 no-reg primary
conference ad-hoc
preference 3
ephone-dn  112  dual-line
conference ad-hoc
preference 2
no huntstop
ephone-dn  113  dual-line
conference ad-hoc
preference 1
no huntstop
ephone-dn  114  dual-line
conference ad-hoc
no huntstop
ephone-dn  115  dual-line
number C002 no-reg primary
conference ad-hoc
preference 3
ephone-dn  116  dual-line
conference ad-hoc
preference 2
no huntstop
ephone-dn  117  dual-line
conference ad-hoc
preference 1
no huntstop
ephone-dn  118  dual-line
conference ad-hoc
no huntstop
ephone-dn  119  dual-line
number C001 no-reg primary
conference ad-hoc
preference 3
ephone-dn  120  dual-line
conference ad-hoc
preference 2
no huntstop
ephone-dn  121  dual-line
conference ad-hoc
preference 1
no huntstop
ephone-dn  122  dual-line
conference ad-hoc
no huntstop
ephone-dn  123
number 704 no-reg primary
park-slot
ephone-dn  124
number 703 no-reg primary
park-slot
ephone-dn  125
number 702 no-reg primary
park-slot
ephone-dn  126
number 701 no-reg primary
park-slot
ephone-dn  127
number A801... no-reg primary
mwi off
ephone-dn  128
number A800... no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address B8FA.E412.0000
max-calls-per-button 2
username "anal1" password xx
type anl
button  1:5
ephone  2
mac-address B8FA.E412.0001
username "anal2" password xx
type anl
button  1:6
ephone  3
mac-address B8FA.E412.0002
username "anal3" password xx
type anl
button  1:7
ephone  4
mac-address B8FA.E412.0003
username "anal4" password xx
type anl
button  1:8
ephone  5
mac-address 0007.0EDD.1B1C
type 7960
ephone  6
video
mac-address C062.6BD2.AFF6
ephone-template 16
username "xx" password xx
paging-dn 1
type ata
button  1:13
ephone  9
mac-address 0021.55D5.4498
ephone-template 16
paging-dn 1
type 7970 addon 1 7914
button  1:86 2m80 3m83 4m88
button  5m23 6m26 7m90 8m33
button  9m87 10m77 11m84 12m28
button  13m16 15m2 16m13 17m10
button  18m85
ephone  10
mac-address C062.6BD2.AB51
ephone-template 16
paging-dn 1
type 7962 addon 1 7914
button  1:84 2m13 3m10 4m83
button  5m80 6m2 7m87 8m26
button  9m23 10m86 11m88 12m16
button  13m85 14m89 15m81 16m82
button  17m90 18m28 19m33
ephone  11
mac-address 0021.5555.C26A
ephone-template 16
paging-dn 1
type 7961
button  1:2 2m80 3m88 4m84
button  5m26 6m90
ephone  12
video
mac-address 081F.F362.371C
ephone-template 16
paging-dn 1
type 7975 addon 1 7916-24
button  1:80 2m83 3m13 4m10
button  5m2 6m26 7m87 8m23
button  9m86 10m88 11m16 12m85
button  13m77 14m81 15m82 16m90
button  17m84 18m28 19m33 30m79
ephone  13
video
mac-address 0012.80F3.B165
ephone-template 16
paging-dn 1
type 7960
button  1:16 2m80 3m88 4m90
button  5m87 6m26
ephone  15
mac-address 0021.55D4.FA43
ephone-template 16
type 7961
button  1:76
ephone  16
video
mac-address 0004.F2E2.C827
ephone-template 16
username "Conf" password xx
paging-dn 1
type 7936
no missed-calls
button  1:79
ephone  17
mac-address 0021.55D5.44C1
ephone-template 16
paging-dn 1
button  1:87 2m80 3m83 4m88
button  5m23 6m86 7m26 8m90
button  10m84 11m28 12m16 14m2
button  15m13 16m10 17m85 18m81
button  19m33 20m82
ephone  18
video
mac-address 0021.55D4.F954
ephone-template 16
paging-dn 1
type 7961
button  1:23 2m83 3m87 4m84
button  5m80 6m88
ephone  20
video
mac-address 0021.55D4.F9D0
ephone-template 16
username "Ext207" password xx
paging-dn 1
type 7961 addon 1 7914
button  1:89 2m87 3m88 4m23
button  5m80 7m84 8m16 9m90
button  10m2 11m13
ephone  21
video
mac-address 0021.55D5.9104
ephone-template 16
paging-dn 1
type 7961
button  1:26 2m83 3m80 4m87
button  5m88 6m2
ephone  22
mac-address 0021.55D4.F9CB
ephone-template 16
type 7961
button  1:78 3m13 4m10 5m80
ephone  23
video
mac-address 0021.55D4.F9F5
ephone-template 16
paging-dn 1
type 7961
button  1:28 2m87 3m23 4m80
button  5m13
ephone  24
mac-address 0021.55D5.9071
ephone-template 16
paging-dn 1
button  1:81 2m13 3m10 5m80
button  6m2 7m87 8m26 9m23
button  10m86 11m88 12m16 13m85
button  14m77 15m90 16m84 17m28
button  18m33
ephone  25
video
mac-address 0021.5555.7843
ephone-template 16
paging-dn 1
type 7961
button  1:85 2m80 3m87 4m88
button  5m13 6m90
ephone  26
mac-address 0022.555D.8D16
ephone-template 16
button  1:83 2m80 3m88 4m23
button  5m86 6m26 7m90 8m33
button  9m13 10m10 11m2 12m87
button  13m16 14m85 15m77 16m81
button  17m82 18m84 19m28
ephone  27
mac-address 0022.555D.8D05
ephone-template 16
paging-dn 1
button  1:88 2m83 3m23 4m80
button  5m33 6m90 7m84 8m86
button  9m13 10m10 11m2 12m26
button  13m87 14m16 15m85 16m77
button  17m81 18m82 19m28
ephone  28
video
mac-address 0023.5EB6.8718
ephone-template 16
paging-dn 1
button  1:33 2m83 3m88 4m80
button  5m86 6m90 7m26 8m23
button  17m82 18m84 19m28 30m79
ephone  29
mac-address 000F.F76E.36FB
type 7960
ephone  31
video
mac-address 0012.80F3.A9D2
ephone-template 16
paging-dn 1
type 7960 addon 1 7914
missed-calls all
button  1:82 2m87 3m88 4m77
button  5m23 6m80 7m86 8m26
button  9m84 10m28 11m16 12m78
button  13m90 14m2 15m13 16m10
button  17m33 18m85 19m81
ephone  32
mac-address 0022.905C.6D38
ephone-template 16
paging-dn 1
button  1:90 2m80 3m83 4m88
button  5m23 6m86 7m26 8m33
ephone-hunt 1 peer
pilot 505
no-reg pilot
statistics collect
banner login
line con 0
login authentication local_authen
no modem enable
transport output telnet
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
exec-timeout 0 0
transport input telnet ssh
transport output telnet ssh
line vty 5 100
no exec
transport input all
line vty 0 4
exec-timeout 0 0
line vty 5 100
scheduler allocate 4000 1000
scheduler interval 500
ntp master
ntp update-calendar
ntp server 192.5.41.40 prefer
ntp server 192.5.41.41
end
Thanks!
1. Why do you have a wildcard in your VM pilot number dial-peer?:
b2bua
codec g711ulaw
no vad
2. I assume you can ping CUE from IOS? (10.1.10.1)
3. Can you do a SIP trace of a call attempt?:
conf t
   logging monitor debugging
   cntrl-z
term mon
debug ccsip mess
u all
-Dan
1.  I'm not certain as to why or where that '50.' wildcard came from...  I went ahead and changed that back to '501'.
2.  I am able to ping 10.1.10.1 from IOS.
3.  I will perform a trace and post the results ASAP.
