UC 540 analog DID trunk FSX/DID card wink start
ericdolton
Beginner
Beginner
Does this card support wink start?  I see the T-1 signaling does but i see not command under the FXS ports for wink start signaling.
UC540(config)#voice-port 0/0/1
UC540(config-voiceport)#signal ?
  groundStart  Ground Start
  loopStart    Loop Start
VIC Slot 0:
        3rd generation - FXS DID Voice daughter card (4 port)
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-27474-02
        Board Revision           : B0
        Deviation Number         : 0
        Fab Version              : 01
        PCB Serial Number        :
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : VIC3-4FXS/DID
        Version Identifier       : V01
        CLEI Code                : TBD
        Longitudinal Calibration : 01 10 10 6F 57 10 10 96
                                   79 10 10 94 A0 10 10 82
Running uc500-advipservicesk9-mz.124-24.SB
ericdolton
Beginner
Beginner
So i figured out that you can not use the built in FXS/DID ports for a DID trunk.  (They should probably look into getting rid of the DID part)  You need to use a VIC module populated with a FSX/DID card.
See this doc.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/C78-557768-00_540_platform_reference_guide_DS_v2a.pdf
Recognize Your Peers
