UC 540 upgrade to 8.1 - no vpn now
shaun.connor
I upgraded a UC540 to 8.1, and my any connect client stopped working...I can get to the website, but when I hit start anyconnect, nothing happens
Is this normal, did the upgrade delete my anyconnect client on the flash?
If it did, can I connect remotely with the vpn client, so I can install the any connect via tftp
thanks
Shaun
Mario Garcia
Level 3
Level 3
Hi Shaun,
If you used the latest version of CCA, then during the upgrade process there is a step that deletes items on the flash, as a clean up process. If you can connect with IPSec client, then go ahead and add the file to the flash using CCA.
