02-11-2014 09:51 AM - edited 03-21-2019 08:04 AM
I am trying to add this to my network to appy updates, but I can not ping it
cable is plugged into
interface FastEthernet0/1/0
IP is set to 192.168.5.89, however, I can not ping it
Any help wold be appreciated
below is config
Y log 2014.02.11 10:02:32 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 27488 bytes
! Last configuration change at 07:00:20 PST Tue Feb 11 2014 by cisco
! NVRAM config last updated at 06:58:27 PST Tue Feb 11 2014 by cisco
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UC540
boot-start-marker
boot-end-marker
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone PST -8 0
clock summer-time PST recurring
crypto pki trustpoint TP-self-signed-2376605861
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2376605861
revocation-check none
rsakeypair TP-self-signed-2376605861
crypto pki certificate chain TP-self-signed-2376605861
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32333736 36303538 3631301E 170D3133 31313139 31383237
31355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 33373636
30353836 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A947 09E3A67F 8F386B05 DC2FE1E8 82CD59E5 F84B3E33 5B95F255 5A7A0466
1073EC90 E8D8205A 751A8B20 914D433A 26F6C1E2 F3E66244 F6418D65 95A70C99
CD666A2D 1DEB63DF 01C7A702 9DA940C1 2C1FCAAB EB3B9DF4 B497512B BB2AADB8
9EC414FE 7A421872 9A80937E 1779321C 294897AE B36F3F43 C40493A8 4A09D7F2
F7BD0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 148A5149 D23AC6AB 0502C4EE BC1EF6BF B03864F2 24301D06
03551D0E 04160414 8A5149D2 3AC6AB05 02C4EEBC 1EF6BFB0 3864F224 300D0609
2A864886 F70D0101 05050003 81810086 FC3081CF 02EFA373 4D4DC28A 6A8FA889
6FBCF449 4EADC98C C5564721 F8DF4F2F 0A883B51 E7822376 76E77B8D 952FC122
CECF2C0A 8478344E 3F3786B3 5DA154DD C85C28AD 7B2C7CF6 62885E60 813C7FEB
FAC18A09 0F4066CC B26BAD36 1CC8EAB7 27D166B1 D815C462 ED045303 1619CD87
5361402D 06A839E9 AF8392DE 742AF8
quit
dot11 syslog
dot11 ssid cisco-data
authentication open
dot11 ssid cisco-voice
vlan 100
authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool data
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
voice call send-alert
voice rtp send-recv
voice service voip
sip
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address 10.1.1.1 port 5060
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
voice translation-rule 1000
rule 1 /.*/ //
voice translation-profile nondialable
translate called 1000
voice-card 0
fax interface-type fax-mail
license udi pid UC540W-FXO-K9 sn FGL174721CZ
archive
log config
logging enable
logging size 600
hidekeys
username cisco privilege 15 secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
ip tftp source-interface Loopback0
bridge irb
interface Vlan1
ip address 192.168.5.89 255.255.255.0
ip access-group 101 in
bridge-group 1
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0
description $FW_OUTSIDE$
no ip address
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
no ip address
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
switchport voice vlan 100
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
switchport mode trunk
no ip address
macro description cisco-switch
interface Dot11Radio0/5/0
no ip address
ssid cisco-data
ssid cisco-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
antenna receive right
antenna transmit right
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
ip address 192.168.5.214 255.255.255.0
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip access-group 102 in
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 192.168.10.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny ip 192.168.10.0 0.0.0.255 any
access-list 101 deny ip 10.1.1.0 0.0.0.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny ip 10.1.10.0 0.0.0.3 any
access-list 102 deny ip 10.1.1.0 0.0.0.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp any 10.1.10.0 0.0.0.3 range 16384 32767
access-list 103 permit udp 10.1.10.0 0.0.0.3 range 16384 32767 any
access-list 103 deny ip 192.168.10.0 0.0.0.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration
access-list 104 remark SDM_ACL Category=1
access-list 104 deny ip 10.1.10.0 0.0.0.3 any
access-list 104 deny ip 192.168.10.0 0.0.0.255 any
access-list 104 deny ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny ip 10.0.0.0 0.255.255.255 any
access-list 104 deny ip 172.16.0.0 0.15.255.255 any
access-list 104 deny ip 192.168.0.0 0.0.255.255 any
access-list 104 deny ip 127.0.0.0 0.255.255.255 any
access-list 104 deny ip host 255.255.255.255 any
access-list 104 deny ip any any
snmp-server community public RO
tftp-server flash:/phones/6901_6911/SCCP6911.9-1-1-0.loads alias SCCP6911.9-1-1-0.loads
tftp-server flash:/phones/6901_6911/SCCP6901.9-1-1-0.loads alias SCCP6901.9-1-1-0.loads
tftp-server flash:/phones/6901_6911/KNL6911SCCP.9-1-1-0.zz.sgn alias KNL6911SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/KNL6901SCCP.9-1-1-0.zz.sgn alias KNL6901SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/BFS6911SCCP.9-1-1-0.zz.sgn alias BFS6911SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/APP6911SCCP.9-1-1-0.zz.sgn alias APP6911SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/APP6901SCCP.9-1-1-0.zz.sgn alias APP6901SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/69xx/SCCP69xx.9-1-1-2-sr.loads alias SCCP69xx.9-1-1-2-sr.loads
tftp-server flash:/phones/69xx/BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:/phones/69xx/DSP69xx.0-0-0-4.zz.sgn alias DSP69xx.0-0-0-4.zz.sgn
tftp-server flash:/phones/69xx/SCCP69xx.9-1-1-2-sr.zz.sgn alias SCCP69xx.9-1-1-2-sr.zz.sgn
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-4-9c.bin alias spa525g-7-4-9c.bin
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-9c.bin alias spa50x-30x-7-4-9c.bin
tftp-server flash:/phones/7906_7911/apps11.9-2-1TH1-13.sbn alias apps11.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/cnu11.9-2-1TH1-13.sbn alias cnu11.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.9-2-1TH1-13.sbn alias cvm11sccp.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/dsp11.9-2-1TH1-13.sbn alias dsp11.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.9-2-1TH1-13.sbn alias jar11sccp.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/SCCP11.9-2-1S.loads alias SCCP11.9-2-1S.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7914/S00105000400.sbn alias S00105000400.sbn
tftp-server flash:/phones/7915/B015-1-0-4.SBN alias B015-1-0-4.SBN
tftp-server flash:/phones/7916/B016-1-0-4.SBN alias B016-1-0-4.SBN
tftp-server flash:/phones/7921/APPS-1.4.1SR1.SBN alias APPS-1.4.1SR1.SBN
tftp-server flash:/phones/7921/CP7921G-1.4.1SR1.LOADS alias CP7921G-1.4.1SR1.LOADS
tftp-server flash:/phones/7921/GUI-1.4.1SR1.SBN alias GUI-1.4.1SR1.SBN
tftp-server flash:/phones/7921/TNUXR-1.4.1SR1.SBN alias TNUXR-1.4.1SR1.SBN
tftp-server flash:/phones/7921/SYS-1.4.1SR1.SBN alias SYS-1.4.1SR1.SBN
tftp-server flash:/phones/7921/TNUX-1.4.1SR1.SBN alias TNUX-1.4.1SR1.SBN
tftp-server flash:/phones/7921/WLAN-1.4.1SR1.SBN alias WLAN-1.4.1SR1.SBN
tftp-server flash:/phones/7925/APPSH-1.4.1SR1.SBN alias APPSH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/CP7925G-1.4.1SR1.LOADS alias CP7925G-1.4.1SR1.LOADS
tftp-server flash:/phones/7925/GUIH-1.4.1SR1.SBN alias GUIH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/JSYSH-1.4.1SR1.SBN alias JSYSH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/JUIH-1.4.1SR1.SBN alias JUIH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/SYSH-1.4.1SR1.SBN alias SYSH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/TNUXH-1.4.1SR1.SBN alias TNUXH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/TNUXRH-1.4.1SR1.SBN alias TNUXRH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/WLANH-1.4.1SR1.SBN alias WLANH-1.4.1SR1.SBN
tftp-server flash:/phones/7931/apps31.9-1-1TH1-16.sbn alias apps31.9-1-1TH1-16.sbn
tftp-server flash:/phones/7931/cnu31.9-1-1TH1-16.sbn alias cnu31.9-1-1TH1-16.sbn
tftp-server flash:/phones/7931/cvm31sccp.9-1-1TH1-16.sbn alias cvm31sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7931/dsp31.9-1-1TH1-16.sbn alias dsp31.9-1-1TH1-16.sbn
tftp-server flash:/phones/7931/jar31sccp.9-1-1TH1-16.sbn alias jar31sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7931/SCCP31.9-1-1SR1S.loads alias SCCP31.9-1-1SR1S.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7936/cmterm_7936.3-3-21-0.bin alias cmterm_7936.3-3-21-0.bin
tftp-server flash:/phones/7937/apps37sccp.1-4-4-0.bin alias apps37sccp.1-4-4-0.bin
tftp-server flash:/phones/7940_7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phones/7940_7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phones/7940_7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phones/7940_7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phones/7941_7961/apps41.9-1-1TH1-16.sbn alias apps41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/cnu41.9-1-1TH1-16.sbn alias cnu41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.9-1-1TH1-16.sbn alias cvm41sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/dsp41.9-1-1TH1-16.sbn alias dsp41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.9-1-1TH1-16.sbn alias jar41sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/SCCP41.9-1-1SR1S.loads alias SCCP41.9-1-1SR1S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7942_7962/apps42.9-1-1TH1-16.sbn alias apps42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/cnu42.9-1-1TH1-16.sbn alias cnu42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.9-1-1TH1-16.sbn alias cvm42sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/dsp42.9-1-1TH1-16.sbn alias dsp42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.9-1-1TH1-16.sbn alias jar42sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/SCCP42.9-1-1SR1S.loads alias SCCP42.9-1-1SR1S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7945_7965/apps45.9-1-1TH1-16.sbn alias apps45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/cnu45.9-1-1TH1-16.sbn alias cnu45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.9-1-1TH1-16.sbn alias cvm45sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/dsp45.9-1-1TH1-16.sbn alias dsp45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.9-1-1TH1-16.sbn alias jar45sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/SCCP45.9-1-1SR1S.loads alias SCCP45.9-1-1SR1S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7970_7971/apps70.9-1-1TH1-16.sbn alias apps70.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/cnu70.9-1-1TH1-16.sbn alias cnu70.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.9-1-1TH1-16.sbn alias cvm70sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/dsp70.9-1-1TH1-16.sbn alias dsp70.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.9-1-1TH1-16.sbn alias jar70sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/SCCP70.9-1-1SR1S.loads alias SCCP70.9-1-1SR1S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7975/apps75.9-1-1TH1-16.sbn alias apps75.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/cnu75.9-1-1TH1-16.sbn alias cnu75.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/cvm75sccp.9-1-1TH1-16.sbn alias cvm75sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/dsp75.9-1-1TH1-16.sbn alias dsp75.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/jar75sccp.9-1-1TH1-16.sbn alias jar75sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/SCCP75.9-1-1SR1S.loads alias SCCP75.9-1-1SR1S.loads
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/phones/8961/dkern8961.100609R2-9-2-2.sebn alias dkern8961.100609R2-9-2-2.sebn
tftp-server flash:/phones/8961/kern8961.9-2-2.sebn alias kern8961.9-2-2.sebn
tftp-server flash:/phones/8961/rootfs8961.9-2-2.sebn alias rootfs8961.9-2-2.sebn
tftp-server flash:/phones/8961/sboot8961.031610R1-9-2-2.sebn alias sboot8961.031610R1-9-2-2.sebn
tftp-server flash:/phones/8961/sip8961.9-2-2.loads alias sip8961.9-2-2.loads
tftp-server flash:/phones/8961/skern8961.022809R2-9-2-2.sebn alias skern8961.022809R2-9-2-2.sebn
tftp-server flash:/phones/9951/dkern9951.100609R2-9-2-2.sebn alias dkern9951.100609R2-9-2-2.sebn
tftp-server flash:/phones/9951/kern9951.9-2-2.sebn alias kern9951.9-2-2.sebn
tftp-server flash:/phones/9951/rootfs9951.9-2-2.sebn alias rootfs9951.9-2-2.sebn
tftp-server flash:/phones/9951/sboot9951.031610R1-9-2-2.sebn alias sboot9951.031610R1-9-2-2.sebn
tftp-server flash:/phones/9951/sip9951.9-2-2.loads alias sip9951.9-2-2.loads
tftp-server flash:/phones/9951/skern9951.022809R2-9-2-2.sebn alias skern9951.022809R2-9-2-2.sebn
tftp-server flash:/phones/9971/dkern9971.100609R2-9-2-2.sebn alias dkern9971.100609R2-9-2-2.sebn
tftp-server flash:/phones/9971/kern9971.9-2-2.sebn alias kern9971.9-2-2.sebn
tftp-server flash:/phones/9971/rootfs9971.9-2-2.sebn alias rootfs9971.9-2-2.sebn
tftp-server flash:/phones/9971/sboot9971.031610R1-9-2-2.sebn alias sboot9971.031610R1-9-2-2.sebn
tftp-server flash:/phones/9971/sip9971.9-2-2.loads alias sip9971.9-2-2.loads
tftp-server flash:/phones/9971/skern9971.022809R2-9-2-2.sebn alias skern9971.022809R2-9-2-2.sebn
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
radius-server attribute 31 send nas-port-detail
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
timeouts ringing infinity
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/0/3
caller-id enable
voice-port 0/1/0
connection plar 201
caller-id enable
voice-port 0/1/1
connection plar 202
caller-id enable
voice-port 0/1/2
connection plar 203
caller-id enable
voice-port 0/1/3
connection plar 204
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description tcatch all dial peer for BRI/PRIv
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
destination-pattern 9T
port 0/1/0
no sip-register
dial-peer voice 51 pots
port 0/1/1
no sip-register
dial-peer voice 52 pots
port 0/1/2
no sip-register
dial-peer voice 53 pots
port 0/1/3
no sip-register
no dial-peer outbound status-check pots
telephony-service
video
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message UC540
load 7914 S00105000400
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7906 SCCP11.9-2-1S
load 7911 SCCP11.9-2-1S
load 7921 CP7921G-1.4.1SR1
load 7925 CP7925G-1.4.1SR1
load 7931 SCCP31.9-1-1SR1S
load 7936 cmterm_7936.3-3-21-0
load 7937 apps37sccp.1-4-4-0
load 7960-7940 P00308010200
load 7941 SCCP41.9-1-1SR1S
load 7941GE SCCP41.9-1-1SR1S
load 7942 SCCP42.9-1-1SR1S
load 7945 SCCP45.9-1-1SR1S
load 7961 SCCP41.9-1-1SR1S
load 7961GE SCCP41.9-1-1SR1S
load 7962 SCCP42.9-1-1SR1S
load 7965 SCCP45.9-1-1SR1S
load 7970 SCCP70.9-1-1SR1S
load 7971 SCCP70.9-1-1SR1S
load 7975 SCCP75.9-1-1SR1S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-9c
load 501G spa50x-30x-7-4-9c
load 502G spa50x-30x-7-4-9c
load 504G spa50x-30x-7-4-9c
load 508G spa50x-30x-7-4-9c
load 509G spa50x-30x-7-4-9c
load 525G2 spa525g-7-4-9c
load 301 spa50x-30x-7-4-9c
load 303 spa50x-30x-7-4-9c
load 6921 SCCP69xx.9-1-1-2-sr
load 6941 SCCP69xx.9-1-1-2-sr
load 6961 SCCP69xx.9-1-1-2-sr
load 6901 SCCP6901.9-1-1-0
load 6911 SCCP6911.9-1-1-0
time-zone 5
keepalive 30 auxiliary 4
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$ggNp$IbROiocdPgBNld7DZVYAC1
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 15
button-layout 7931 2
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone 1
device-security-mode none
mac-address C600.FB6A.0001
max-calls-per-button 2
type anl
ephone 2
mac-address C600.FB6A.0002
type anl
ephone 3
mac-address C600.FB6A.0003
type anl
ephone 4
mac-address C600.FB6A.0000
type anl
ephone 5
mac-address 001E.F7C4.64B2
type 7940
banner login ^CUC500 Base Config - Manufacturing 8.6.0 ^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
end
02-11-2014 06:45 PM
Hi Allen,
show ip int br | exc unass
show inventory
post the output of the following command:
Kevin
02-12-2014 06:28 AM
Kevin,
here you go
I am plugged into fa0/1/0, a second or two after I plug in I loose the link light
We have another UC 540 on the same subent, I am plugged into a POE trunked switcch port on a cisco ESW-540-24p, the switch is not reporting any errors....
Thanks for any help
UC540#
UC540#show inventory
NAME: "UC540W-FXO-K9 Chassis", DESCR: "UC540W-FXO-K9 Chassis"
PID: UC540W-FXO-K9 , VID: V01, SN: FGL174721CZ
Interface IP-Address OK? Method Status Prot ocol
In0/0 10.1.10.2 YES unset up up
Vlan1 192.168.5.110 YES manual up down
NVI0 10.1.10.2 YES unset up up
BVI100 10.1.1.1 YES NVRAM up up
Loopback0 10.1.10.2 YES NVRAM up up
