Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
For some reason I'm only able to get the AA to work in PBX mode. If I try Blend or Key System, when someone calls in, the line rings it seems like the AA picks up but I get silence. I would like to use the Key system config.
Please send your configuration through Configuration Utility -> Services -> Feedback, input "Attention wenyang@cisco.com" at Issues or suggestions section. I will take a look and get back to you.
Best regards,
Wendy
Learn, share, save
