UC320W how to upload a AA prompt
joshxx1..
I want to upload an Auto Attendant prompt that was done for the company to my UC320 but i see no option to do that.
Is there a way to do that without doing it from a ip phone connected to the system.
Thanks.
wenyang
Level 4
Level 4
You can upload AA prompt with Configure Utility at Auto Attendant->Prompts, there is Upload button for each prompt. You can click on upload button and upload the sound file from your computer.
Best regards,
Wendy
wenyang
Level 4
Level 4
Best regards,
Wendy
Thanks i didnt have the option because my uc320 is behind a firewall and i didnt connect the UC to the internet but after that it worked.
Thanks.
Someone needs to explain to me why the ability to upload an AA Prompt is not appearing in the Configuration Utility.  My UC320W is connected to the Internet and I can make and receive calls, but I do not have the option to upload AA Prompts.  I had the option 6 months ago, but no longer have the option.  I have not made any changes to my firewall or the UC320W.  I just need to upload the new AA greeting.
