09-01-2013 05:38 PM - edited 03-21-2019 07:43 AM
hi,
I have my system working,
one of the phones is in french, the voicemail is also in french.
now when I hit DND on that phone or (NTD)=DND when someone calls they get the message in english saying "sorry extenxion xxxx is unavailable"...
any way for me to put the DND in french when someone calls that phone which is set to french?
Solved! Go to Solution.
09-03-2013 10:10 AM
I think you have not read my answer above, again:
Messages to callers are only given with the global primary language.
09-02-2013 10:09 AM
Check that your global voicemail primary, or only language is French.
If it is not, messages to caller will be played in English.
09-02-2013 05:46 PM
I don't understand... are you saying that if the system defalt language is english then dnd will play in english?
because the user at ext: 201 my own phone, the phone and the vm is in french already but when I hit dnd it plays dnd in english.
can this be set per user or it's a system wide setting?
09-03-2013 02:16 AM
As answered above.
09-03-2013 06:23 AM
voicemail for myself is set to canadian french.
when I connect to unity to get mailbox services it's in french.
when someone calls me and I hit DND the message is in english.
09-03-2013 10:10 AM
09-03-2013 10:29 AM
thanks
09-03-2013 11:18 AM
Note: cisco does not recognize that is a bug and will not even fix it.
You can try recording a custom absence-type message to be played instead of standard.
Thank you for the nice rating and good luck!
