UC500 support for SRTP, SRTCP and TLS?
Mike Clements
Can anyone tell me if the UC520 running the latest support pack has support for SRTP (over UDP), SRTCP (over TCP) and/or TLS encryption?
I would like to encrypt the SIP trunks from the UC500 to our SIP provider.
After that I would like to encrypt from the UC500 to the handset if there is any advice on how to do that as well?
MC
paolo bevilacqua
That is described in the CME admin guide and/or other IOS documents.
Since is very onerous, complicated and limiting, I recommend that you are very careful and do lab tests before committing to your customer.
Ta, is there a particular CME admin guide/IOS document that is applicable to the UC500 in this situation?  I have seen it described in many CME guides but none were relevant to the UC500 i.e. reference to commands that don't exist etc...
MC
You may have looked at a newer CME/IOS release, other that that commands are same and identical.
