UC520 - After Software Pack Update problem with IP Phone CP-7937G
Jochen Brenner
after update our UC520 to the Software Pack 8.6.1 I have a problem with IP Phone CP-7937G. I reboot the Phone and I get the message on the phone display "Change language" and the phone will automatically start again and again?
I have install two locale packs UC500_8.6.1_locale_de_DE.zip, UC500_8.6.1_locale_en_US.zip and the default Phone locale is German.
My Software Versions
Software Verison: 15.1(4)M5
Software Pack: 8.6.1
IOS: uc500-advipservicesk9-mz.151-4.M5
CME: 8.6
Voicemail: 8.6.5
All other IP Phones 7961...works fine. Can everbody help me?
2 Accepted Solutions
Hello Jochen,
Please run the following command:
dir flash:/its | i .jar
if the output looks like the following:
251 -rw- 69843 Nov 20 2012 20:37:24 +01:00 user_define_4_rp-sccp.jar
Please add the following under config mode:
(config)# tftp-server flash:/its/user_define_4_rp-sccp.jar
if it is user_define_5_ just change accordingly.
HTH,
Alex
*Please rate helpful posts
Helllo Jochen,
Yes, you can and it is recommended if now the phone is working.
Best regards,
Alex
6 Replies 6
Jochen Brenner
Any ideas?
Hello Jochen,
HTH,
Alex
I can solved the problem. I have read this post:
https://supportforums.cisco.com/message/3794925#3794925
and this solved my problem.
I do this:
   262  -rw-       74885  Mar 11 2013 12:20:34 +01:00  user_define_4_gp-sccp.jar
   263  -rw-       61913  Mar 11 2013 12:20:36 +01:00  user_define_4_ipc-sccp.jar
   267  -rw-       71712  Mar 11 2013 12:20:38 +01:00  user_define_4_tc-sccp.jar
   265  -rw-       69770  Mar 11 2013 12:20:38 +01:00  user_define_4_rp-sccp.jar
   260  -rw-       61838  Mar 11 2013 12:20:34 +01:00  user_define_4_be-sccp.jar
   264  -rw-       61653  Mar 11 2013 12:20:36 +01:00  user_define_4_mk-sccp.jar
   268  -rw-       61913  Mar 11 2013 12:20:40 +01:00  user_define_4_td-sccp.jar
after that I register my IP Phone 7937G and restart the phone. After the restart the phone comes up and working correctly with the German locale.
Can someone explain to me what does the above command do?
Thank you!
Hello Jochen,
Thank you for the rating.
This adds the specified file to the TFTP with correct path.
Best regards,
Alex
Hi Alexander,
can I "write" the config after this command:
Helllo Jochen,
Best regards,
Alex
