uc520 cue stuck in a loop
andrewsymms
Hello
Dont know why but cue seems to have stopped working and if I do a service-module integrated-service-engine 0/0 session i get a screen that just scrolls over and over. status says trying to recover from reset/shutdown.
Ive looked on here but not found the answer yet
any help would be appreciated
6 Replies 6
Faris Hamdan
Hello Andrew,
I think that it will be a good idea to proceed with the boot helper procedure while facing this behaviour.
UC 500 Boot Helper Instructions:
https://supportforums.cisco.com/docs/DOC-13686
I hope that this helps.
Faris
Hello
Thanks for your reply
I tried that procedure but once I do service-module integrated-service-engine 0/0 session the screen fills with output and pressing ctrl-shift-x  6 will not break the cycle. only way back is to close telnet session and log in again
Andrew
attached is the output after inputing "service-module integrated-service-engine 0/0 session"
Looks like you have a bad CUE module.  It is internal and not field replaceable..  I think you will need to RMA the unit.
It seems to be a Kernel panic, a problem with mounting root file system.
I think that it will be better to open a case with Cisco Tac to troubleshoot, I do agree that i might end up with an RMA for the whole unit.
Faris
Hello
Just an update opened a tac as suggested and the outcome was an RMA. Spent a couple of evenings reconfiguring new unit and after wrestling with cue localisation for uk everything is up and running fine now thanks for all your assistance
Andrew
