UC520 - multiple SIP Trunks with different credentials
support
a customer of me uses a UC560 (IOS 15.1.4)
I have to configure two SIP-Trunks, one for SIP-Provider and another for a door station.
Both trunks need different credentials
my config is:
credentials username 1111 password 0 1234 realm Provider1
credentials username 2222 password 0 9876 realm doorstation
registrar 1 dns:Provider1 expires 3600
registrar 2 ipv4:doorstation expires 3600
sip-server dns:Provider1
When I execute a "show sip-ua register status", I see, that both credentials used for both SIP-Trunks
exampe:
--------------------- Registrar-Index  1 ---------------------
Line                             peer       expires(sec) registered P-Associ-URI
1111                             -1         909          yes
2222                             -1         70           no
--------------------- Registrar-Index  2 ---------------------
1111                             -1         18           no
2222                             -1         2410         yes
on "debug ccsip message" I see, that the UC is trying to register with doorstation credentials for the SIP-Provider trunk and also trying to register with SIP-Provider credentials on the doorstation.
What can I do, to prevent the UC560 using both credentials for both trunks?
thank you
Matthias
paolo bevilacqua
You can't do anything, as it is not supported. A major IOS limitation that Cisco does not even acknowledge.
I had already supposed this.
If I change the credentials on doorstation, it should work, right?
You can try and report.
