08-21-2013 04:05 PM - edited 03-21-2019 07:41 AM
hi,
got my uc520 working, inbound calls work rigth away but outbound calls take a long time...
so when I run any sort of debug on my uc520, I dial a number let's say 9 555 555 5555 it will take about 15 seconds before anything shows up in my debugs.
so it does work but calling out not sure what happens takes a long time.
this is all with a sip provider.
I know it,s not the sip provider because as I said before any debug information is showed on my console between me dialing the number and hitting DIAL and the time anything shows up it takes about 15 seconds.
ideas?
08-21-2013 05:08 PM
Configure interdigit timeout to 3 or 4.
And dial-peers with the correct pattern and number of digits, avoid using T
08-21-2013 05:14 PM
in CCA my interdigit is 5 seconds.
how do I change dialpeers from within CCA?
08-22-2013 03:43 AM
I have no idea about CCA.
08-24-2013 04:27 PM
so here is the test I did today,
my UC520 at home is behind my isp's (linksys type device) so my uc520 gets a 192.168.x.x
so behind my own isp it takes a good 20 seconds before the phone I'm calling rings.
I took my device and put it in my dad's house where my uc520 gets the public ip, dhcp but still I get the public ip.
it takes about 5 seconds which is normal.
any idea why in my house before any debug starts showing up in my terminal why it takes about 15...20 seconds and when the uc has the public ip it takes about 3 to 5 seconds?
I just run
debug ccsip messages.
my dad,s internet I get the public ip it after 3 seconds debug information shows up.
on my internet it takes about 20 seconds before any debug information shows up and my uc gets a 192.168.x.x from the providers modem/router device.
thanks
08-24-2013 06:23 PM
just to add,
pinging the registrar from the router is instantanious so its not dns related.
08-26-2013 03:05 PM
It seems like an issue with the router in front of the UC then. How do you have that router configured in regards to SIP?
-john
