08-01-2013 05:57 AM - edited 03-21-2019 07:37 AM
I have a config file for a uc520-32U-4bri-k9 and need to restore this to a UC-520-48U-6BRI.
I get the error in CCA THE SELECTED CONFIGURATION IS INCOMPATABLE WITH THE SELECTED DEVICE.
Can anyone suggest a fix?
08-06-2013 04:26 AM
Use CLI.
08-07-2013 12:16 AM
Hi Jonathan,
You will not be able to restore the previous configuration to the new device as they have different hardware. You will need to strip out the conflicting configurations and then you may be able to restore via CCA. Otherwise you will have to rebuild via CLI.
-Trent Good
** Please rate useful posts! **
