UC520 - Software Pack update new webinterface and questions about that
Jochen Brenner
Hi guys,
after a software pack (8.6.1) update to our UC520 we have a new webinterface. In the old webinterface (software pack 7.0.0) all users can login to the webinterface and can configure her phones. For an example the speed dial menu.
I the new webinterface I can not found configuration opportunitys for the phones? Can everybody help me?
Thank you!
2 Accepted Solutions
you can get to the interface
10.1.10.1\ccme.html
there is also a tick box somewhere in cca that says allow users web access to phones.
no, because you shouldnt really be going to this backend anymore.
but, my error above was that i said, 10.1.10.1 when it should be 10.1.1.1\ccme.html
so unless you want to create your own redirect.
8 Replies 8
paolo bevilacqua
You don't need web interface to configure speed-dials. That can be done from the phone services menu.
I know, but the users would like her phones with the webinterface. Is it no longer possible?
It is, has not changed.
Hello Paolo,
I can only see this menu in the webinterface:
Configure -> Users, Groups
Voicemail -> Mailboxes ...
10.1.10.1\ccme.html
thank you! I was on the wrong interface. -> /admin/Common/HomePage.do
/ccme.html works!
Thank you!
can I change the default redirect? I connect with my browser to:
http://uc520.test.lan/
and I redirect to http://uc520.test.lan/admin
and I get and error 404 not found.
When I connect direct to http://uc520.test.lan/ccme.html works correct and I can login to the ccme.
