12-09-2010 05:05 AM - edited 03-21-2019 03:23 AM
Our UC520 has been configured for using a VPN setup. The router has been configured to allow port 500, 10000 and 4500. When we start a connection via the Cisco VPN Client it will connect and receive an IP-address. Looking in the UC520 ip route table we see the correct routes. Although when we try to ping the UC520 from the client it fails, when we try to ping the client from the UC520 it fails as well. The UC520 is configured with NAT behind a Netgear WNDR3700
These are the commands we entered for adding VPN functionality to the UC520:
aaa new-model
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
username vpn secret 5 $1$8mLF$OY9VTfy0Lo5O4aPR60wkb1
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key P@ssw0rd1
dns 192.168.2.1
pool SDM_POOL_1
save-password
max-users 10
crypto isakmp profile sdm-ike-profile-1
match identity group EZVPN_GROUP_1
client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
client configuration address respond
virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
crypto isakmp nat keepalive 20
interface Virtual-Template1 type tunnel
ip nat inside
ip virtual-reassembly
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
ip local pool SDM_POOL_1 192.168.2.150 192.168.2.159
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/1/8 overload
access-list 105 remark SDM_ACL Category=2
access-list 105 permit ip 10.10.10.0 0.0.0.3 any
access-list 105 permit ip 192.168.1.0 0.0.0.255 any
access-list 105 permit ip 192.168.2.0 0.0.0.255 any
access-list 105 permit ip 192.168.10.0 0.0.0.255 any
!route-map SDM_RMAP_1 permit 1
match ip address 105
This is the show ip-route output from the UC520 whilst the client is connected:
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.1.1
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.10.10.0/24 is directly connected, Vlan100
L 10.10.10.1/32 is directly connected, Vlan100
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Vlan1
L 192.168.1.25/32 is directly connected, Vlan1
192.168.2.0/24 is variably subnetted, 3 subnets, 2 masks
C 192.168.2.0/24 is directly connected, Loopback2
L 192.168.2.25/32 is directly connected, Loopback2
S 192.168.2.152/32 [1/0] via 93.95.xxx.xxx, Virtual-Access2
192.168.10.0/24 is variably subnetted, 3 subnets, 2 masks
C 192.168.10.0/30 is directly connected, Loopback0
L 192.168.10.1/32 is directly connected, Loopback0
S 192.168.10.2/32 is directly connected, Integrated-Service-Engine0/0
Client configuration whilst connected:
IP: 192.168.2.152
Mask: 255.255.255.0
Gateway: 192.168.2.25
DNS: 192.168.2.1
Solved! Go to Solution.
12-09-2010 08:19 AM
Looks like the NAT configuration isn't right. Add the following to access-list 105 and make sure these are the first entries for the ACL:
access-list 105 deny ip 10.10.10.0 0.0.0.3 192.168.2.0 0.0.0.255
access-list 105 deny ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 105 deny ip 192.168.2.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 105 deny ip 192.168.10.0 0.0.0.255 192.168.2.0 0.0.0.255
Cole
12-09-2010 08:19 AM
Cole
12-09-2010 10:32 AM
Thanks for your reply. The ACL has been changed but the result is the same, no reply to the ping request.
Below the adjusted ACL:
access-list 105 deny ip any host 192.168.1.150
access-list 105 deny ip any host 192.168.1.151
access-list 105 deny ip any host 192.168.1.152
access-list 105 deny ip any host 192.168.1.153
access-list 105 deny ip any host 192.168.1.154
access-list 105 deny ip any host 192.168.1.155
access-list 105 deny ip any host 192.168.1.156
access-list 105 deny ip any host 192.168.1.157
access-list 105 deny ip any host 192.168.1.158
access-list 105 deny ip any host 192.168.1.159
12-10-2010 09:23 AM
We have decided to remove NAT and work without it. This solved our problem instantly.
