UC520 - with a Microsoft SBS2003
hakim.benayed
I have a SBS2003 server who is the DHCP server (192.168.1.1) and I want to install the UC520 in this network.
Please give me the best practice!
BR
hakim.benayed
I need an urgent help! Thx
As I said the UC520 in a normal configuration is the DHCP server and the SBS2003 also, so, there is a problem.
I can't change the IP adress of the SBS2003 who is the 192.168.1.1
As I understand, I have to desactivate the DHCP on the UC520 and change the address range to [192.168.1.1;192.168.1.256], is it true?
If it's ok! I've got a problem, I have to change the adress of the UC520 from 192.168.1.1 to 192.168.1.2! Can you confirm it and give me the best method?
Many thx.
BR
Search next time
https://supportforums.cisco.com/message/3430838
I also don't use the DHCP functionality on the UC, just change the default IP address and remove the DHCP server after applying the configuration.
Don't forget to save settings!
Good Luck
Thanx for the link!
I'll search next time!
I'll test it and be back to give my feed back
BR
I finished the installation and it works!
BR
