UC540 AA Script edit for No Input
microaid
I am trying to configure the AA script to dial the Blast Group if no numbers are input when the main prompt plays.
I am trying to account for the inbvound call being on a rotary phone that cannot press a button.
I have uploaded the script to the script editor but i can't seem to get the function i desire.
Todd
David Trad
Hi Todd,
If I am not mistaken when you are in CCA and are modifying the settings you can choose to send a no input to a destination, or if they press zero to "Zero Out" you can also send this to a destination, both should be able to point to a blast group...
Are you using CCA to manage the AA?
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hi David,
Yes i am using the CCA to manage the AA but the script I created in the Web Gui of the UC.
When you use that Web Gui script on the UC it makes a Custom script and i believe it removes the option you are talking about.
I need to pull the script into the CUE editor and add this, I had ask-cue create the last one but replicating it does not seem to work.
Todd
Hi Todd,
Ahhh I cannot help you there sadly
I have not used the CUE script editor in the web GUI I jut normally use CCA to manage the AA.
Sorry about that..
Cheers,
David.
