Log into the CUE module from CLI
service module integrated service engine session
Then login in
at the prompt use paste this in
To check any problems at CUE, run the following traces:
no trace all
clear trace
trace voicemail msgnotif all
trace configapi smtp debug
trace entitymanager NotifDevice all
trace smtp all
sho trace buffer tail
Then test your voicemail by leaving messages you will get everything you need with this trace to find the reason why your email is not working on the command line.
use control c to stop the trace
