11-09-2011 09:34 AM - edited 03-21-2019 04:55 AM
I have a customer running a UC540 software pack 8.2 who wants to be able to have a receptionist initiate a conference call, then she would drop off of the call and leave the other 2 parties connected. I cannot see how to do this. Any help or suggestions would be appreciated.
11-09-2011 10:14 AM
Hello Chris,
I just tested this in my lab, and I did not have any problems. The receptionist should be able to just hit the "confrn" button, then dial the other party, hit "confrn" again, and all three phones will then be in the conference. At that point, the receptionist should be able to just hang up on the call, and the other two phones should remain connected.
Thank you,
Darren
11-10-2011 07:53 AM
Darren, I've tested on the UC on our office and when the creator hangs up the call(s) drop. Based on the post from Marcus, it appears I may be able to configure the ephone-template to ensure that the conference orginator can hang up and not drop the other calls.
Thoughts
Chris
11-09-2011 05:54 PM
By default the ephone-template is configured to not drop the call if the creator drops. If that does not happen for you, apply the follow command under the ephone template that is used by all of your ephones. The command can be applied to the ephone or template. Make sure that your ephones don't have varying commands as far as this goes.
ephone-template 15
conference drop-mode local
Here is the description under the command in IOS.
Creator The active conference terminates when the conference creator hangs up.
Local The active conference terminates when the last local party in the conference hangs up or drops out of the conference.
11-10-2011 07:53 AM
Thanks Marcus, I will try in my lab at the office where I had the same problem and post my results.
Chris
11-14-2011 09:08 AM
It works! Thanks for the input!
Chris
11-14-2011 11:02 AM
NP
