UC540 connecting to PA system
SteveOrfanos
Level 5
Level 5
Hi all,
We have a customer who has an existing UC540 and would like to purchase a PA system to interface into UC540. Can anyone recommend a particular model that interfaces seemlessly (FXS ports). Customer is located in Australia.
Many Thanks
Nathan Compton
Level 4
Level 4
I'm a big fan of Valcom.  I know of the V-2003 which is a 3-zone paging system, but they have a single zone page system as well.  I've used their technical support before, and they are top notch.
I know Bogen's TAMB will make a FXS work with just about any paging system you can think of.
Adam Compton
David Trad
Hi Steve,
I Hope this helps you out
Check out my post HERE on it...
This is mainly an Australian solution but could be useful to others abroad.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
