UC560 : 2E1 + 2BRI+ 2FXO+ 2FXS ?
mbenrouhou
Hello, We have a costumer who needs to deploy an IPBX for around 30 remote site, each site has arround 30 users, we're thinking about proposing UC500, but the need is very strange, the costumer needs : 1 x E1 port + 2 x BRI + 2 x FXO to connect GSM gateway + 2 x FXS to connect a fax & alarm. What is the best option that can we propose ?
paolo bevilacqua
Do you intend to deploy 30 phone systems ? That can be good for sales but quickly become a nightmare to manage.
Realistically you could look at a 900 users centralized system with as few gateways as possible, eg Vg202 or ata 187, etc.
David Trad
Hi There,
I believe that you are considering the wrong system, especially if I read you right, this will be a centrally hosted system at say site "A" and the rest of the other offices will be hanging of it.
If this is the case you should either consider the BE6000 or maybe even CUCMB, and if you are not certified for either one of them, then you should then consider partnering with a Cisco partner that is.
Are you going through any consultation process right now?
Cheers,
David Trad.
**When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) **
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
