UC560 AA "No Option Transfer To" not working
Jon Allen
       I have set up the AA for a UC560, but the "No Option Transer to" will not work.  I just keeps looping the AA.  Any help would be appreciated.
David Mowery
Can you try setting the Maximum Menu Prompt Attempts to 1?
6 Replies 6
trgood
Hi Jon,
Can you send me a screenshot of your AA configuration?
-Trent Good
-Trent Good ** Please rate useful posts! **
Here is the link to the image AA config page.
http://proponentit.com/AA.PNG
Hi John,
Your configuration looks correct.  Some things I would try are changing the prompt to a self recorded one and checking the firmware version.
I'm not aware of any issues that cause the No option transfer to not to work.
You may consider opening a case so that an engineer can troubleshoot more in depth.
David Mowery
this was going to be my simple suggestion.
im sure its just playing the AA message, for the number of failed attempts setting.
Thank you David and Yasien,
That was the issue.
