11-04-2010 07:29 AM - edited 03-21-2019 03:14 AM
Hi all,
I'm trying to create an stcapp extension for an analog phone as an ephone-dn. However, I need to block long distance and international calling from the handset as it's in a public area of the building.
I was able to successfully get this working as a dial-peer on voice port 0/0/2, but I'd prefer to set it up as an ephone so it shows up properly in the directory and when calling internally as well as adding a monitor button for the receptionist.
Here's the config I am using right now, which is working as a dial peer:
! voice translation-rule 999 rule 1 reject /^91..\(.*\)/ rule 2 reject /^90\(.*\)/ rule 3 reject /77./ rule 4 reject /191/ ! voice translation-profile callblock translate called 999 ! voice-port 0/0/2 caller-id enable ! dial-peer voice 254 pots description x397 Plant Phone translation-profile incoming callblock translation-profile outgoing callblock call-block translation-profile incoming callblock destination-pattern 397 port 0/0/2 !
However, when I change it to this:
! voice translation-rule 999 rule 1 reject /^91..\(.*\)/ rule 2 reject /^90\(.*\)/ rule 3 reject /77./ rule 4 reject /191/ ! voice translation-profile callblock translate called 999 ! voice-port 0/0/2 caller-id enable ! dial-peer voice 254 pots description x397 Plant Phone translation-profile incoming callblock translation-profile outgoing callblock call-block translation-profile incoming callblock service stcapp port 0/0/2 ! ephone-dn 41 dual-line number 397 no-reg primary label Plant description Plant name Plant ! ephone 97 device-security-mode none mac-address FBD4.091A.2002 max-calls-per-button 2 provision-tag 397 type anl button 1:41 !
The call blocks no longer work and the phone can call any number.
Any insight would be appreciated,
Thank you.
Edit: I should add, we are using SIP Trunks for all calls
11-04-2010 08:00 AM
Use CCA 2.2.5 to create the analog phone connected to an FXS port as User Mode phone.
This adds it as an ephone and ephone-dn.
Then it will appear in Telephony:VOice: User Extensions, where you can select restrictions (bottom right).
CCA will create everything for you.
11-04-2010 09:09 AM
Thanks for the quick reply steve.
I would love to use CCA, it certainly would make my life a lot easier with this stuff... However, the cisco partner who did the initial configuration used CLI for everything and left a huge mess behind. Because of that, when I go into CCA Voice Tab, I am greeted with over 20 errors. Some are just user name / first name / last name errors that could be resolved, but there are 6 extension not unique errors that concern me. I'm hesistant to go deleting phones or even changing extensions since we finally managed to get everything working to a point we're comfortable with.
Thanks again
11-04-2010 12:14 PM
The translation-profile should be applied incoming on the ephone-dn instead of dial-peer. When CCA sets up an STCAPP dial-peer it should look like this:
service stcapp
port 0/0/2
label Plant
description Plant
name Plant
Adam Compton
