UC560 - Don't display "Forwarded to"
CoDeC
We have a UC560. Our users want to know if it's possible not show the text "Forwarded to" when a call arrive forwarded from other extension.
Is it possible?
Thank you so much.
Cheers!!!
Alberto
David Trad
Hi Alberto,
This if I am not mistaken is a back-end feature, I cannot find any CLI codes to turn this off.
I have tried three different combitionations so far, I will spend a little more time on it, but I am fairly certain this cannot be turned of, I will see if there is a work around though.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
