I have my uc560 with a sip trunk and a fxo line
I use the fxo line to have fax to email, and is working fine
But i also need one more fax machine with a internal extension that will be accessed by the sip trunk, my ISP supports t.38
My max machine is my fxs port 0/0/0 and in the cca was configured as fax
dial-peer voice 1 pots
description ** CCA Analog Fax **
destination-pattern 3309
port 0/0/0
no sip-register
Globally i configured the t38
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
And in all incoming and outgoing dial-peers of the sip trunk
dial-peer voice 20 voip
corlist outgoing llamada-local
description ** Llamadas locales **
translation-profile outgoing Salida_PSTN
preference 2
destination-pattern 9[2-7]......
session protocol sipv2
session target sip-server
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 3002 voip
description fax2
translation-profile incoming fax2_Called_10
incoming called-number 4011115
When is try to send a fax to the 4011115 that have a translation-rule to 3309, the fax tone sounds a moment and late hung
So, i will like to know?
1. If a have fax to mail enable, can i have fax relay to fxs port?
2. If its possible, is something wrong with my configuration?
3. Which debugs can i applied to check alls rigth?
