11-09-2010 06:13 PM - edited 03-21-2019 03:15 AM
Can you use the PRI on the UC560 & the SR520 T-1 at same time (essentially have 2 PRIs) and is it manageable thru CCA?
Solved! Go to Solution.
11-09-2010 07:12 PM
The UC500 series only supports T1 circuits provisioned for PRI. The SR520-T1 router only supports circuits provisioned for data. You can have your UC560 configured to use a PRI attached to that device and also use a data T1 on the SR520 at the same time. Both of which are configurable via CCA.
Cole
11-09-2010 07:12 PM
Cole
11-09-2010 07:14 PM
Somehow I was under impression that SR520 supported PRIs. Thanks
11-09-2010 07:15 PM
Can you add second PRI card on UC560?
11-09-2010 07:19 PM
Yep.
