02-20-2019 02:05 AM - edited 02-20-2019 02:13 AM
The phones are currently on the upgrade screen but only shows mac address and not IP address and then power cycles. Phones are connected to a POE switch. I have configured the router for VOIP and as a TFTP server.
C3825Router#sho run
Building configuration...
Current configuration : 12123 bytes
! Last configuration change at 11:28:51 CST Thu Jan 24 2019
! NVRAM config last updated at 07:08:27 CST Thu Jan 24 2019
version 15.1
hostname C3825Router
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone CST -6 0
clock summer-time CDT recurring
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.10.25.1 10.10.25.15
ip dhcp excluded-address 10.10.35.1 10.10.35.15
ip dhcp pool Data
network 10.10.25.0 255.255.255.0
default-router 10.10.25.1
option 66 ip 10.10.25.1
option 150 ip 10.10.25.1
dns-server 75.75.75.75 75.75.76.76 1.1.1.1 1.0.0.1
ip dhcp pool Voice
network 10.10.35.0 255.255.255.0
default-router 10.10.35.1
option 66 ip 10.10.35.1
option 150 ip 0.10.35.1
ip name-server 1.1.1.1
ip name-server 1.0.0.1
no ipv6 cef
voice-card 0
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
registrar server expires max 3600 min 120
voice register global
mode cme
source-address 10.10.35.9 port 5060
max-dn 40
max-pool 42
load 7960-7940 P0S3-07-4-00
tftp-path flash:
file text
create profile sync 0000840745363414
voice register dn 1
number 2001
allow watch
name PH-2001
label 2001
mwi
voice register dn 2
number 2002
allow watch
name PH-2002
label 2002
mwi
voice register dn 3
number 2003
allow watch
name PH-2003
label 2003
mwi
voice register dn 4
number 2004
allow watch
name PH-2004
label 2004
mwi
voice register dn 5
number 2005
allow watch
name PH-2005
label 2005
mwi
voice register dn 6
number 2006
allow watch
name PH-2006
label 2006
mwi
voice register dn 7
number 2007
allow watch
name PH-2007
label 2007
mwi
voice register dn 8
number 2008
allow watch
name PH-2008
label 2008
mwi
voice register dn 9
number 2009
allow watch
name PH-2009
label 2009
mwi
voice register dn 10
number 2010
allow watch
name PH-2010
label 2010
mwi
license udi pid CISCO3825 sn FTX0937A3DP
redundancy
interface GigabitEthernet0/0
description WAN
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
description LAN
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.25
description LAN-Data
encapsulation dot1Q 25 native
ip address 10.10.25.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.35
description LAN-Voice
encapsulation dot1Q 35
ip address 10.10.35.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
logging esm config
access-list 101 permit ip 10.10.0.0 0.0.255.255 any
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/CiscoLogo.png
tftp-server flash:Desktops/320x212x12/FOUNTAIN.PNG
tftp-server flash:Desktops/320x212x12/LIST.XML
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Thumbs.db
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:CME8_6/Ringtones/Analog1.raw
tftp-server flash:CME8_6/Ringtones/Analog2.raw
tftp-server flash:CME8_6/Ringtones/AreYouThere.raw
tftp-server flash:CME8_6/Ringtones/AreYouThereF.raw
tftp-server flash:CME8_6/Ringtones/Bass.raw
tftp-server flash:CME8_6/Ringtones/CallBack.raw
tftp-server flash:CME8_6/Ringtones/Chime.raw
tftp-server flash:CME8_6/Ringtones/Classic1.raw
tftp-server flash:CME8_6/Ringtones/Classic2.raw
tftp-server flash:CME8_6/Ringtones/ClockShop.raw
tftp-server flash:CME8_6/Ringtones/DistinctiveRingList.xml
tftp-server flash:CME8_6/Ringtones/Drums1.raw
tftp-server flash:CME8_6/Ringtones/Drums2.raw
tftp-server flash:CME8_6/Ringtones/FilmScore.raw
tftp-server flash:CME8_6/Ringtones/HarpSynth.raw
tftp-server flash:CME8_6/Ringtones/Jamaica.raw
tftp-server flash:CME8_6/Ringtones/KotoEffect.raw
tftp-server flash:CME8_6/Ringtones/MusicBox.raw
tftp-server flash:CME8_6/Ringtones/Piano1.raw
tftp-server flash:CME8_6/Ringtones/Piano2.raw
tftp-server flash:CME8_6/Ringtones/Pop.raw
tftp-server flash:CME8_6/Ringtones/Pulse1.raw
tftp-server flash:CME8_6/Ringtones/Ring1.raw
tftp-server flash:CME8_6/Ringtones/Ring2.raw
tftp-server flash:CME8_6/Ringtones/Ring3.raw
tftp-server flash:CME8_6/Ringtones/Ring4.raw
tftp-server flash:CME8_6/Ringtones/Ring5.raw
tftp-server flash:CME8_6/Ringtones/Ring6.raw
tftp-server flash:CME8_6/Ringtones/Ring7.raw
tftp-server flash:CME8_6/Ringtones/Ringlist.xml
tftp-server flash:CME8_6/Ringtones/Sax1.raw
tftp-server flash:CME8_6/Ringtones/Sax2.raw
tftp-server flash:CME8_6/Ringtones/Vibe.raw
tftp-server flash:/DIALPLAN.XML
tftp-server flash:music-on-hold.au
tftp-server flash:P003-07-5-00.sbn
tftp-server flash:P0S3-07-5-00.bin
tftp-server flash:P0S3-07-5-00.loads
tftp-server flash:P0S3-07-5-00.sb2
tftp-server flash:P003-07-5-00.bin
tftp-server flash:P00308010200.bin
tftp-server flash:P00308010200.loads
tftp-server flash:P00308010200.sb2
tftp-server flash:P00308010200.sbn
tftp-server flash:cmterm-7940-7960-sccp.8-1-2.cop
tftp-server flash:cmterm-7940-7960-sccp.8-1-2.cop.sgn
tftp-server flash:cmterm-7940-7960-sccp.8-1-2.exe
tftp-server flash:cmterm-7940-7960-sccp.8-1-2.zip
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/7942-7962.tar
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/apps42.9-3-1ES26.sbn
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/cnu42.9-3-1ES26.sbn
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/cvm42sccp.9-3-1ES26.sbn
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/dsp42.9-3-1ES26.sbn
tftp-server flash:SCCP-Phones/7942G-7962G/cmterm-7942_7962-sccp.9-3-1SR4-1/jar42sccp.9-3-1ES26.sbn
tftp-server flash:SCCP-PhG-1S.loads
tftp-server flash:SCCP-Phones/7945G-7965G/cmterm-7945_7965-sccp.9-3-1SR4-1/term45.default.loads
tftp-server flash:CME8_6/SCCP42.8-_6/term06.default.loads
tftp-server flash:CME8_6/term11.default.loads
tftp-server flash:CME8_6/term31.default.loads
tftp-server flash:CME8_6/term41.default.loads
tftp-server flash:P00307020300.loads
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
sip-ua
credentials number 13098635246 username GV13098635246 password 7 08764E5A5F03242137005E3D2227 realm GVGW
authentication username GV13098635246 password 7 073529187A031A5D433A331D35
registrar dns:gvgw3.simonics.com:5070 expires 1800 tcp
sip-server dns:gvgw3.simonics.com:5070
telephony-service
moh-file-buffer 2000
max-ephones 30
max-dn 50
ip source-address 10.10.35.2 port 2000
ip qos dscp af31 signal
service dnis overlay
service dnis dir-lookup
timeouts interdigit 2
system message Ciscoland.net
cnf-file location flash:
load 7960-7940 P00307020300
load 7941 SCCP41.9-3-1SR4-1S
load 7942 SCCP42.9-3-1SR4-1S
load 7945 SCCP45.9-2-1S
load 7961 SCCP41.9-3-1SR4-1S
load 7962 SCCP42.9-3-1SR4-1S
load 7965 SCCP45.9-3-1SR4-1S
dialplan-pattern 1 5... extension-length 4
max-conferences 4 gain -6
moh music-on-hold.au
multicast moh 239.1.1.1 port 2000 route 10.10.25.1 10.10.35.1
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
directory entry 1 2580 name Human Resources
directory entry 2 2648 name IT Help Desk
directory entry 3 2860 name Security
directory entry 4 4286 name Front Desk
directory entry 5 8620 name Grounds Maintence
directory entry 6 8684 name Confrence Room
directory entry 7 2448 name Break Roon
directory entry 8 2864 name Building Maintence
directory entry 9 4884 name Computer Room
directory entry 10 8684 name Living Room
directory entry 11 2448 name Kitchen
directory entry 12 2864 name Bedroom 2 - Brandon
directory entry 13 8888 name Server/Networking Room
directory entry 14 8666 name DJ Laptop
create cnf-files version-stamp 7960 Jan 24 2019 07:02:49
ephone-dn 1 dual-line
number 2580
label 2580
description Human Resources
hold-alert 30 originator
ephone-dn 2 dual-line
number 2648
label 2648
description IT Help Desk
name IT Help Desk
ephone-dn 3 dual-line
number 2860
label 2860
description Security
name Security
ephone-dn 4 dual-line
number 4286
label 4286
description Front Desk
name Front Desk
ephone-dn 5 dual-line
number 4884
label 4884
description Computer Room
name Computer Room
ephone-dn 6 dual-line
number 8684
label 8684
description Living Room
name Living Room
ephone-dn 7 dual-line
number 2448
label 2448
description Kitchen
name Kitchen
ephone-dn 8 dual-line
number 2864
label 2864
description Bedroom 2 - Brandon
ephone-dn 9 dual-line
number 8888
label 8888
description Server/Networking Room
name Phone Server/Networking Room
ephone-dn 12 dual-line
number 8666
label DJ Laptop
name DJ Laptop
ephone 1
device-security-mode none
mac-address 000B.BEAD.4D4F
type 7960
button 1:1
ephone 2
mac-address 0011.92BA.230B
speed-dial 1 2860 label "Security"
speed-dial 2 2580 label "Human Resources"
speed-dial 3 4286 label "Front Desk"
speed-dial 4 1010 label "Lab"
type 7960
button 1:2
ephone 3
mac-address 000F.8FC6.9EE8
type 7960
button 1:3
ephone 4
mac-address 000B.BEAD.42CF
type 7960
button 1:4
ephone 5
mac-address C062.6BD3.2E41
type 7945
button 1:5
ephone 6
mac-address 0023.339B.F76B
type 7945
button 1:6
ephone 7
mac-address 0021.A02C.A957
type 7945
button 1:7
ephone 8
mac-address 0021.A02C.C59C
type 7945
button 1:8
ephone 9
mac-address 34BD.C82D.4CDB
type 7945
button 1:9
ephone 10
ephone 11
ephone 12
mac-address F01F.AF46.3036
type CIPC
button 1:12
ephone 13
ephone 15
ephone 17
ephone 18
alias exec con conf t
alias exec sib show ip int brief
alias exec srb show run | b
alias exec sri show run int
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
login
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
login
scheduler allocate 20000 1000
ntp server 3.us.pool.ntp.org
ntp server 0.us.pool.ntp.org
ntp server 2.us.pool.ntp.org
ntp server us.pool.ntp.org
ntp server 1.us.pool.ntp.org
end
C3825Router#wr
[OK]
C3825Router#
C3825Router#sho run
! NVRAM config last updated at 18:47:03 CST Thu Jan 24 2019
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp pool Data
ip dhcp pool Voice
no ipv6 cef
voice-card 0
voice service voip
sip
mode cme
max-dn 40
max-pool 42
tftp-path flash:
file text
voice register dn 1
number 2001
allow watch
name PH-2001
label 2001
mwi
voice register dn 2
number 2002
allow watch
name PH-2002
label 2002
mwi
voice register dn 3
number 2003
allow watch
name PH-2003
label 2003
mwi
voice register dn 4
number 2004
allow watch
name PH-2004
label 2004
mwi
voice register dn 5
number 2005
allow watch
name PH-2005
label 2005
mwi
voice register dn 6
number 2006
allow watch
name PH-2006
label 2006
mwi
voice register dn 7
number 2007
allow watch
name PH-2007
label 2007
mwi
voice register dn 8
number 2008
allow watch
name PH-2008
label 2008
mwi
voice register dn 9
number 2009
allow watch
name PH-2009
label 2009
mwi
number 2010
allow watch
name PH-2010
label 2010
mwi
redundancy
description WAN
ip address dhcp
ip nat outside
duplex auto
speed auto
media-type rj45
description LAN
no ip address
duplex auto
speed auto
media-type rj45
ip nat inside
ip nat inside
no ip http server
logging esm config
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
sip-ua
telephony-service
max-ephones 30
max-dn 50
dn-webedit
time-webedit
number 2580
label 2580
number 2648
label 2648
name IT Help Desk
number 2860
label 2860
name Security
number 4286
label 4286
name Front Desk
number 4884
label 4884
name Computer Room
number 8684
label 8684
name Living Room
number 2448
label 2448
description Kitchen
name Kitchen
number 2864
label 2864
number 8888
label 8888
number 8666
label DJ Laptop
name DJ Laptop
ephone 1
type 7960
button 1:1
ephone 2
type 7960
button 1:2
ephone 3
type 7960
button 1:3
ephone 4
type 7960
button 1:4
ephone 5
type 7945
button 1:5
ephone 6
type 7945
button 1:6
ephone 7
type 7945
button 1:7
ephone 8
type 7945
button 1:8
ephone 9
type 7945
button 1:9
ephone 10
ephone 11
ephone 12
type CIPC
button 1:12
ephone 13
ephone 15
ephone 17
ephone 18
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
login
line vty 5 15
privilege level 15
login
end
C3825Router#
3750E-48PD#sho run
Current configuration : 9648 bytes
! Last configuration change at 11:58:58 CST Wed Jan 23 2019
! NVRAM config last updated at 11:48:57 CST Wed Jan 23 2019
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 3750E-48PD
no aaa new-model
switch 1 provision ws-c3750e-48pd
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/1
switchport access vlan 25
switchport mode access
switchport voice vlan 35
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
switchport access vlan 35
switchport trunk native vlan 25
switchport mode trunk
speed 1000
duplex full
interface GigabitEthernet1/0/48
speed 1000
duplex full
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface Vlan1
no ip address
shutdown
interface Vlan11
description Management
ip address 10.10.11.4 255.255.255.0
interface Vlan25
description Data
ip address 10.10.25.4 255.255.255.0
interface Vlan35
description Voice
ip address 10.10.35.4 255.255.255.0
ip default-gateway 10.10.35.1
ip classless
ip http server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
ntp clock-period 36026370
ntp server 204.11.201.10
ntp server 64.6.144.6
ntp server 198.55.111.50
ntp server 173.230.144.109
end
3750E-48PD#
C3825Router#sho run
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp pool Data
ip dhcp pool Voice
no ipv6 cef
voice-card 0
voice service voip
sip
mode cme
max-dn 40
max-pool 42
tftp-path flash:
file text
voice register dn 1
number 2001
allow watch
name PH-2001
label 2001
mwi
voice register dn 2
number 2002
allow watch
name PH-2002
label 2002
mwi
voice register dn 3
number 2003
allow watch
name PH-2003
label 2003
mwi
voice register dn 4
number 2004
allow watch
name PH-2004
label 2004
mwi
voice register dn 5
number 2005
allow watch
name PH-2005
label 2005
mwi
voice register dn 6
number 2006
allow watch
name PH-2006
label 2006
mwi
voice register dn 7
number 2007
allow watch
name PH-2007
label 2007
mwi
voice register dn 8
number 2008
allow watch
name PH-2008
label 2008
mwi
voice register dn 9
number 2009
allow watch
name PH-2009
label 2009
mwi
number 2010
allow watch
name PH-2010
label 2010
mwi
redundancy
description WAN
ip address dhcp
ip nat outside
duplex auto
speed auto
media-type rj45
description LAN
no ip address
duplex auto
speed auto
media-type rj45
ip nat inside
ip nat inside
no ip http server
logging esm config
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
sip-ua
telephony-service
max-ephones 30
max-dn 50
dn-webedit
time-webedit
number 2580
label 2580
number 2648
label 2648
name IT Help Desk
number 2860
label 2860
name Security
number 4286
label 4286
name Front Desk
number 4884
label 4884
name Computer Room
number 8684
label 8684
name Living Room
number 2448
label 2448
description Kitchen
name Kitchen
number 2864
label 2864
number 8888
label 8888
number 8666
label DJ Laptop
name DJ Laptop
ephone 1
type 7960
button 1:1
ephone 2
type 7960
button 1:2
ephone 3
type 7960
button 1:3
ephone 4
type 7960
button 1:4
ephone 5
type 7945
button 1:5
ephone 6
type 7945
button 1:6
ephone 7
type 7945
button 1:7
ephone 8
type 7945
button 1:8
ephone 9
type 7945
button 1:9
ephone 10
ephone 11
ephone 12
type CIPC
button 1:12
ephone 13
ephone 15
ephone 17
ephone 18
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
login
line vty 5 15
privilege level 15
login
end
C3825Router#wr
[OK]
C3825Router#
C3825Router#sho run
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp pool Data
ip dhcp pool Voice
no ipv6 cef
voice-card 0
voice service voip
sip
mode cme
max-dn 40
max-pool 42
tftp-path flash:
file text
voice register dn 1
number 2001
allow watch
name PH-2001
label 2001
mwi
voice register dn 2
number 2002
allow watch
name PH-2002
label 2002
mwi
voice register dn 3
number 2003
allow watch
name PH-2003
label 2003
mwi
voice register dn 4
number 2004
allow watch
name PH-2004
label 2004
mwi
voice register dn 5
number 2005
allow watch
name PH-2005
label 2005
mwi
voice register dn 6
number 2006
allow watch
name PH-2006
label 2006
mwi
voice register dn 7
number 2007
allow watch
name PH-2007
label 2007
mwi
voice register dn 8
number 2008
allow watch
name PH-2008
label 2008
mwi
voice register dn 9
number 2009
allow watch
name PH-2009
label 2009
mwi
number 2010
allow watch
name PH-2010
label 2010
mwi
redundancy
description WAN
ip address dhcp
ip nat outside
duplex auto
speed auto
media-type rj45
description LAN
no ip address
duplex auto
speed auto
media-type rj45
ip nat inside
ip nat inside
no ip http server
logging esm config
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
sip-ua
telephony-service
max-ephones 30
max-dn 50
dn-webedit
time-webedit
number 2580
label 2580
number 2648
label 2648
name IT Help Desk
number 2860
label 2860
name Security
number 4286
label 4286
name Front Desk
number 4884
label 4884
name Computer Room
number 8684
label 8684
name Living Room
number 2448
label 2448
description Kitchen
name Kitchen
number 2864
label 2864
number 8888
label 8888
number 8666
label DJ Laptop
name DJ Laptop
ephone 1
type 7960
button 1:1
ephone 2
type 7960
button 1:2
ephone 3
type 7960
button 1:3
ephone 4
type 7960
button 1:4
ephone 5
type 7945
button 1:5
ephone 6
type 7945
button 1:6
ephone 7
type 7945
button 1:7
ephone 8
type 7945
button 1:8
ephone 9
type 7945
button 1:9
ephone 10
ephone 11
ephone 12
type CIPC
button 1:12
ephone 13
ephone 15
ephone 17
ephone 18
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
login
line vty 5 15
privilege level 15
login
end
C3825Router#
3750E-48PD#sho run
version 12.2
no service pad
hostname 3750E-48PD
no aaa new-model
ip subnet-zero
no file verify auto
no ip address
shutdown
speed 1000
duplex full
speed 1000
duplex full
interface Vlan1
no ip address
shutdown
interface Vlan11
interface Vlan25
description Data
interface Vlan35
description Voice
ip classless
ip http server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
3750E-48PD#
03-27-2019 11:23 PM
@bkepley93 wrote:Unable to get 7960 IP phones and 7945G IP phones to grab an IP address from dhcp on its upgrading screen.
ip dhcp pool Voice
IP address 0.10.35.1 may be considered invalid. DHCP responze can be rejected because of it and/or phone may reboot.
Just guessing ...
04-25-2019 03:19 PM
I will give that a try and respond back with a status
04-25-2019 06:12 PM
I have fixed that error and still getting the same issue
