Unable to route calls to voice mail for voip calls across 2 sites
Okechi Awujo
Hi All
Any help here will be really appriciated...
I have 2 sites with UC560 on both ends... there is a direct LAN connecttion between the 2 sites.. A voip dail-peer route calls accross the sites.. however if you make a voip call to either sites and there is no pick up there is a fast busy tone instead of forwaring to voice mail.. if you call externally from one site to the other and there is no answer the calls is forwarded to vioce mail ok... what am i doing wrong..
Please help
regards
Okechi
2 Accepted Solutions
danplacek
Level 4
Level 4
With site-to-site and voicemail, 2 things to take a look at:
1. Codecs -- CUE does not accept anything other than G711. If you are not using G711 across the WAN, make sure it is being transcoded properly.
2. SIP -- I've seen the remote system send a "BYE ALSO" or a "REFER" instead of doing B2BUA... which could potentially give you a busy tone depending on how things are setup.
If you could do a "debug ccsip messages" that would help alot.
David Trad
Hi Okechi,
Daniel hit the nail on the head 90% of the time, the issue is that the right codec is not set right for CUE transactions, this is common with site-2-site calling, make sure that the dial-peer pointing to the VM is set with a forced G.711uLaw codec.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
6 Replies 6
rowseyba1
Okechi,
Have you completed a debug voip ccapi inout on each side?
One thing I would check and make sure that your voicemail pilot is different on each side.
The voice mail pilot is different on each side.. however, they have the same IP Address ie the default ip address for the CUE..can that be the cause??
That should not matter.  Would you be able to provide the debug mentioned above along with a debug ccsip messages from both sides?
Please provide the orginating call number, and the receiving call number in your reply.
danplacek
Level 4
Level 4
David Trad
Hi Okechi,
Cheers,
David.
Thanks Daniel and David.. sorry it took me a while to update.. it worked after setting the voip dial peer to use G.711uLaw.
thanks a lot guys..
Cheers
Okechi
