Unified CallConnector Operator
oliverpowell
We are installing a eval version of UCC operator in standalone deployment.
Trouble is we can't even log into the application to see how it works or test it.
We run through the installation process and it reboots the PC. When we try to login it fails with either bad username or password, or the server.
As this can't be a server issue as its pointing to itself (Standalone), it must be a username and password problem.
We have tried every user and pass it could be - IP phone user and pass, local PC user and pass, Admin user and pass but nothing is working.
Has anyone had this same problem?
Slightly embarrassing to have to post such a question but its causing some pain......it cannot be that difficult!
We cannot log into the config manager either. Is there a default username and password for this?
Any help appreciated.
Oli
janickle
You should be able to login to the new install using the username cisco and password cisco.
Thank you,
Jason Nickle
janickle
Thank you,
Jason Nickle
Hi Jason,
Yes, we discovered this now. Fairly embarrassed but I don't recall seeing this anywhere in the documentation.
Hence why this wasn't tested.
Thanks for your reply
Oli
