08-18-2010 03:34 PM - edited 03-21-2019 02:53 AM
All,
All voice mail rom either internal or external callers are off by 7 hours.
We are configured for PST.
Please advise.
It seems like CUE or CME may by the culprit.
Solved! Go to Solution.
08-19-2010 12:47 PM
The Ping tool may think a 4/5 success is fail. Not sure. But I do know that when you change the time zone on the CUE, it has to be reloaded.
But your 'show clock' was matching, so a little confusing. I wonder if you can do a maintenance window reload (after saving everything you have)?
08-19-2010 05:57 AM
The bottom of the screen is cut off. Do you have NTP alive and activated.
Is CUE also set with the correct time zone?
uc520_fxo_3#sh clock
08:55:39.143 EDT Thu Aug 19 2010
uc520_fxo_3#service-module integrated-Service-Engine 0/0 session
Trying 10.1.10.2, 2002 ... Open
banner login ^Cisco Configuration Assistant. Version: 2.2 (5). Wed Aug 18 16:37:07 EDT 2010^
User Access Verification
Username: ciscoadmin
Password:
se-10-1-10-1# show clock
08:56:01.116 EDT Thu Aug 19 2010
08-19-2010 11:53 AM
Steven,
Yes, and Yes. But I noticed that the CCA states "NTP Server ...is not reachable. I use sundial.columbia.edu's IP address but also tried another NTP, 69.167.160.102, with the same result in CCA. However, I can ping both IPs from a local file server...I CANNOT ping the NTPs from the UC... why would that happen?
UC_540#sho clock
11:27:43.316 PDT Thu Aug 19 2010
UC_540#service-module integrated-Service-Engine 0/0 session
Cisco Configuration Assistant. Version: 2.2 (4). Thu Aug 05 10:51:58 PDT 2010
Username: Cisco
Password:
se-10-1-10-1#
se-10-1-10-1# sho clock
11:29:52.086 PDT Thu Aug 19 2010
se-10-1-10-1#
Thank you,
John.
08-19-2010 12:02 PM
I found that the UC is denying the NTP on access list 104, but why?
Shouldn't configuring NTP via CCA add NTP access and allow NTP to occur?
Also, in this error message the error time stamp is ahead by 7 hours....
Thanks...
08-19-2010 12:19 PM
Update,
I went into CCA and used its PING tool to PING the two different NTP servers and it worked. After that I re-entered the NTP server by name in the NTP section os the CCA system time, and now IT IS ALIVE.
Go figure - not sure if this was a timing thing for the UC or if the PING forced the issue.
The time stamp is still off, but whatever is responsible for the UC's error messages time stamp as seen in CCA troublshoot>system Status is the culprint.
Thanks in advance..
John
08-19-2010 12:47 PM
08-19-2010 12:54 PM
Looks like the reload fixed the timestamp. I am alos confused by the fact that it Sho'd correct...
Thank you.
08-19-2010 03:15 PM
No, Thank YOU!!!!!!!
