Watch/Monitor Buttons do not show the correct state
david
I programmed several Watch buttons on SPA500 module and some buttons stay lit red even though the phones are not used.  When pressing the button it does call the Vacant phone.
How can I fix the state to be correct and only be lit red when the corrsponding phone is used?
It should be working based on the config.
Could you try removing the button from the phone you are watching and readd it?  Could you try removing the watch for that button and readding it?
16 Replies 16
Steven Smith
Level 7
Level 7
Can you provide your config and a show ephone register?  Remember to remove passwords.
Not sure how to:
"provide your config and a show ephone register?  Remember to remove passwords"
Do you mean show running-config?
Yes, that is what I mean.
The Button in 12 0n extension 200 and it is suppose to watch X223
Attached is show ephone register:
Can you provide the entire config?  Please remember to remove passwords.
Here it is
I programmed it to be none and the light is off
I programmed it to be watch 223 and the light came on (X223 is not using the phone)
The only thing to verify is that DND is not enabled on the phone.  The show ephone register had -1 for the phone it was trying to monitor, which is incorrect.  If it doesn't think it has a phone to monitor, or the phone isn't registered (which is not your case), it will show as red.
DND is not on X223
We can also call it with no problems
I tried putting X223 in DND and taking it our of DND and the light is still on.
This problem is on my in house UC540.  I am trying to install a UC560 with 70 phones and I have the same behavavior almost 33% of the buttons are lit red without a reason.  Worst yet I can not even program the keys. I started a new Discussion on the matter.
David Trad
Hi David,
I have seen this problem before when the phone registers but doesnt actually register properly I.E it registers in ITS mode.
The best way to see if that particular phone is registering properly is to debug tftp events
ROUTER# debug tftp event
ROUTER# term mon
Look for any errors and report them.
Also you may want to look at doing a factory reset of the phone, this has helped me in the past, also check and make sure that there is no newer Loads for the phone.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
FActory Reset did not fix the problem
Attached is the report from the debug tftp event
I am not sure what to look for
Hi David,
The TFT Debug doesnt screem anything out at me sadly :(
Can you please better explain the scenario for me, and i do have a couple of questions:
  1. Why on earth did CCA create so many ephone-hunt sequentials (10 to be exact and for BACD which is not being used it would seem)??? Is this CCA doing its typical excessive code syndrome or did you instruct CCA to put them in?
  2. Which phone is monitoring ephone-dn  14? On your config you posted there is no phone monitoring extension 200 (Ephone-DN 14) so i am not sure what is going on or what your trying to achieve but this could potentialy be the problem unless i have missed it somewhere.
  3. Again there appears to be so much excess code there from CCA, can i suggest you maybe clean them out, it makes for diagnoses a nightmare as you have to shuffle through them all to identify what is in use and what is not in use.
I will continue to look over your config, but i suspect you have the phones monitoring a non-existant Directory Number, this would cause the constant BLF light.
I have a serious gripe/problem with how much excessive code CCA leaves behind, i honestly till this day do not know why CCA was programmed to do that, i know they are probably thinking ahead and for future work to be done, but in some instances CCA would need to delete them and re-create them in order to apply certain fields/changes, they also use up resources if i am not mistaken wich i see no need for.
If you get the chance give the system a bit of  clean up, a lean system is a good healthy system ;)
I wait for your update.
Cheers,
David.
Hi Guys,
Was this problem ever resolved?
I am having the same issue. Cisco CME on 2851 router. We have several Cisco 7970 IP Phones all provisioned at the same time, and all working fine. I have a 7914 module monitoring the phones and one is showing as off hook. (BLF -1).
The phone that is showing offhook is ephone 7, it is being monitored by ephone 4. I have done factory reset, firmware upgrade, reset and everything recommended above but still having the issue. The red light indicates that the phone is offhook or not present although it is cleary registered to the CME.
You can see from the show ephone register below (ephone 4 is monitoring ephone 7) that ephone 7 is showing as offhook when it is not and is also registered and working. It shows:
button 33: cw:1 ccw:(0 0)
  dn 22 number 122 CH1   IDLE         CH2   IDLE         watch(BLF on phone -1) shared with monitor-ring
I have attached config and tftp debug below. If any one can shed some light it would be much appreciated.
------------------ show running-config ------------------
Building configuration...
Current configuration : 33299 bytes
! Last configuration change at 18:09:53 AEST Mon Jun 4 2012
! NVRAM config last updated at 18:09:56 AEST Mon Jun 4 2012
version 15.1
hostname CISCO
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.151-4.M1.bin
boot-end-marker
card type t1 0 0
! card type command needed for slot/vwic-slot 0/1
enable password
aaa new-model
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
clock timezone AEST 10 0
no network-clock-participate wic 0
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1 10.0.0.199
ip dhcp pool cisco
network 10.0.0.0 255.255.255.0
option 150 ip 10.0.0.1
default-router 10.0.0.138 10.0.0.1
dns-server x.x.x.x x.x.x.x
ip name-server x.x.x.x
no ipv6 cef
password encryption aes
voice service voip
ip address trusted list
  ipv4 204.9.161.164
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
h323
vpn-group 1
  vpn-gateway 1 http://10.0.0.15
  vpn-trustpoint 1 trustpoint _Certificate leaf
  vpn-hash-algorithm sha-1
vpn-profile 1
  host-id-check disable
sip
  registrar server expires max 3600 min 3600
  localhost dns:sip.skype.com
voice class codec 1
codec preference 1 g711ulaw
voice class permanent 1
signal timing oos restart 50000
signal timing oos timeout disabled
signal keepalive disabled
signal sequence oos no-action
voice class custom-cptone telstra
dualtone disconnect
  frequency 425
  cadence 375 375
voice class custom-cptone conference
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class custom-cptone jointone
dualtone conference
  frequency 600 900
voice class custom-cptone leavetone
dualtone conference
  frequency 400 800
  cadence 400 100 200 100 200 100
voice register global
mode cme
source-address 10.0.0.1 port 5060
max-dn 25
max-pool 25
authenticate register
timezone 47
hold-alert
mwi stutter
voicemail 999
tftp-path flash:
create profile sync 0007934814052285
voice register dn  1
number 201
name B iPhone
no-reg
label 201
voice register dn  2
number 202
name D iPhone
no-reg
label 202
voice register dn  3
number 203
name C iPhone
no-reg
label 203
voice register dn  4
number 204
name K iPad
no-reg
label 204
voice register pool  1
registration-timer max 720 min 660
id mac 50EA.D669.27A3
session-transport tcp
type CiscoMobile-iOS
number 1 dn 1
dtmf-relay rtp-nte
username user201 password 201
no vad
voice register pool  2
id mac 148F.C646.6CFA
number 1 dn 2
dtmf-relay rtp-nte
username user202 password 202
no vad
voice register pool  3
id mac DC2B.6198.4F3D
number 1 dn 3
dtmf-relay rtp-nte
username user203 password 203
no vad
voice register pool  4
id mac 70DE.E239.73B8
number 1 dn 4
dtmf-relay rtp-nte
username user204 password 204
no vad
voice translation-rule 1
rule 1 /\(.*\)/ /100/
voice translation-rule 2
rule 1 /^.*/ /xxxxxxxxxxxxxx/
voice translation-rule 3
rule 1 /617xxxxxxxx/ /130/
voice translation-rule 4
rule 1 /^004\(........\)/ /614\1/
rule 2 /^099\(.*\)/ /\1/
rule 3 /^0\(.*\)/ /\1/
voice translation-rule 5
rule 2 /\(.*\)/ /100/
voice translation-profile INBOUND
translate called 5
voice translation-profile PSTN_Outbound
translate calling 2
translate called 4
voice translation-profile SKYPE_IN
translate called 3
voice-card 0
dspfarm
dsp services dspfarm
interface Loopback0
ip address 11.1.1.1 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 11.1.1.1
interface Loopback2
ip address 10.10.10.10 255.255.255.0
interface Tunnel1
no ip address
interface GigabitEthernet0/0
description ETH-LAN
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/1
description $ETH-LAN$
ip address 192.168.0.1 255.255.255.0
ip access-group 2 in
duplex auto
speed auto
no cdp enable
interface Service-Engine1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.0.0.20 255.255.255.0
service-module ip default-gateway 10.0.0.1
no cdp enable
interface Virtual-Template1 type tunnel
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Virtual-Template2
ip unnumbered Loopback2
interface Vif1
ip address 192.168.11.1 255.255.255.252
ip pim dense-mode
ip local pool SDM_POOL_1 10.0.0.75 10.0.0.95
ip local pool SDM_POOL_2 10.1.0.2 10.1.0.50
ip local pool SDM_POOL_3 192.168.1.50 192.168.1.60
no ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:gui
ip flow-export destination 10.0.0.239 2055
ip nat inside source list VPNAccess interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.0.0.138
ip access-list standard public
ip access-list extended VPNAccess
remark Allow VPN clients to access LAN
remark CCP_ACL Category=2
remark Allow CPN local LAN
permit ip 192.168.1.0 0.0.0.255 any
access-list 100 remark CCP_ACL Category=4
access-list 100 permit ip 10.0.0.0 0.0.0.255 any
no cdp run
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:apps70.8-3-0-50.sbn
tftp-server flash:cnu70.8-3-0-50.sbn
tftp-server flash:cvm70sccp.8-3-0-50.sbn
tftp-server flash:dsp70.8-3-0-50.sbn
tftp-server flash:jar70sccp.8-3-0-50.sbn
tftp-server flash:S00105000300.sbn
tftp-server flash:SCCP70.8-3-1S.loads
tftp-server flash:XMLDefault.cnf.xml
tftp-server flash:United_States/g3-tones.xml
tftp-server flash:English_United_States/td-sccp.jar
tftp-server flash:English_United_States/ipc-sccp.jar
tftp-server flash:P00308000600.bin
tftp-server flash:P00308000600.sb2
tftp-server flash:P00308000600.loads
tftp-server flash:P00308000600.sbn
tftp-server flash:apps70.8-4-1-23.sbn
tftp-server flash:cnu70.8-4-1-23.sbn
tftp-server flash:cvm70sccp.8-4-1-23.sbn
tftp-server flash:dsp70.8-4-1-23.sbn
tftp-server flash:jar70sccp.8-4-1-23.sbn
tftp-server flash:SCCP70.8-4-2S.loads
tftp-server flash:S00105000400.sbn
tftp-server flash:RingList.xml
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:apps70.9-0-3TH1-22.sbn
tftp-server flash:cnu70.9-0-3TH1-22.sbn
tftp-server flash:cvm70sccp.9-0-3TH1-22.sbn
tftp-server flash:dsp70.9-0-3TH1-22.sbn
tftp-server flash:jar70sccp.9-0-3TH1-22.sbn
tftp-server flash:SCCP70.9-0-3S.loads
tftp-server flash:apps45.9-0-3TH1-22.sbn
tftp-server flash:cnu45.9-0-3TH1-22.sbn
tftp-server flash:cvm45sccp.9-0-3TH1-22.sbn
tftp-server flash:dsp45.9-0-3TH1-22.sbn
tftp-server flash:jar45sccp.9-0-3TH1-22.sbn
tftp-server flash:SCCP45.9-0-3S.loads
tftp-server flash:term65.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:cmterm_7936.3-3-21-0.bin
control-plane
voice-port 0/2/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone telstra
no battery-reversal
cptone AU
timeouts interdigit 5
timeouts call-disconnect 2
timeouts wait-release 2
timing hookflash-out 250
impedance complex1
caller-id enable
voice-port 0/2/1
no battery-reversal
cptone AU
impedance complex1
caller-id enable
voice-port 0/2/2
no battery-reversal
cptone AU
impedance complex1
caller-id enable
voice-port 0/2/3
no battery-reversal
cptone AU
impedance complex1
caller-id enable
voice-port 0/3/0
auto-cut-through
voice-port 0/3/1
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.0.0.1 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register confdsp1
keepalive retries 5
dspfarm profile 1 conference
codec g711ulaw
codec g729br8
codec g729r8
codec g711alaw
codec g729ar8
codec g729abr8
maximum conference-participants 16
maximum sessions 3
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
associate application SCCP
dial-peer voice 1 pots
translation-profile incoming INBOUND
preference 3
destination-pattern 0T
direct-inward-dial
port 0/2/0
dial-peer voice 2 pots
preference 2
direct-inward-dial
port 0/2/1
dial-peer voice 3 pots
preference 1
direct-inward-dial
port 0/2/2
dial-peer voice 4 pots
shutdown
port 0/2/3
dial-peer voice 10 voip
destination-pattern 99.
session protocol sipv2
session target ipv4:10.0.0.20
incoming called-number .
dtmf-relay cisco-rtp
codec g711ulaw
no vad
dial-peer voice 100 voip
description **Incoming Call from Skype SIP Trunk**
translation-profile incoming SKYPE_IN
session target sip-server
incoming called-number .%
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 101 voip
description **Outgoing Call from Skype SIP Trunk**
translation-profile outgoing PSTN_Outbound
destination-pattern 004........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 5 pots
description **Outgoing Mobile Failover**
preference 4
destination-pattern *04........
direct-inward-dial
port 0/2/2
dial-peer voice 102 voip
description **Outgoing Call to Skype - THAILAND**
destination-pattern 066.........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 103 voip
description **Outgoing Call to Skype - UK**
destination-pattern 044..........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 104 voip
description **Outgoing Call to Skype - Internat-ALL**
destination-pattern 099T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 700 voip
destination-pattern 70.
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 712 voip
destination-pattern A712
session protocol multicast
session target ipv4:237.111.0.0:22222
voice-class permanent 1
codec g711ulaw
vad aggressive
dial-peer voice 713 voip
destination-pattern A713
session target ipv4:237.111.0.1:22222
codec g711ulaw
vad aggressive
dial-peer voice 70 pots
preference 1
destination-pattern 712
dial-peer voice 71 pots
preference 2
dial-peer voice 72 pots
preference 3
sip-ua
credentials username xxxxxxxxxxxxxx password 7 realm sip.skype.com
authentication username xxxxxxxxxxxxxx password 7
no remote-party-id
retry invite 2
retry register 10
registrar dns:sip.skype.com expires 3600
sip-server dns:sip.skype.com
host-registrar
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 3
sdspfarm tag 1 confdsp1
conference hardware
video
authentication credential xxxxx xxxxx
xml user xxxxx password xxxxx 15
max-ephones 96
max-dn 110 no-reg
ip source-address 10.0.0.1 port 2000
auto assign 1 to 24
service phone videoCapability 1
system message xxxxx Pty Ltd
url directories http://10.0.0.1:80/localdirectory
url services http://10.0.0.20/voiceview/common/login.do
url authentication http://10.0.0.1/CCMCIP/authenticate.asp
cnf-file perphone
load 7914 S00105000400
load 7936 cmterm_7936.3-3-21-0
load 7960-7940 P00308000600
load 7965 term65.default
load 7970 term70.default
time-zone 47
time-format 24
date-format dd-mm-yy
live-record 998
voicemail 999
max-conferences 3 gain -6
call-park system application
moh music-on-hold.au
web admin system name xxxxx secret 5 xxxxxxxxxxxxxxxx
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 0
transfer-pattern 2..
transfer-pattern 7..
secondary-dialtone 0
directory entry 1 100 name Reception
fac standard
create cnf-files version-stamp 7960 Jun 04 2012 17:24:26
ephone-template  1
url services 2 http://xxxxxxlawyers.com/phone/xmldir/PhoneUI/ xxxxxxLawyers_DIRECTORY
url services 3 http://jivait.com/phone/rss2cisco.pl NEWS@
park reservation-group 1
softkeys idle  Dnd Newcall Gpickup Pickup Cfwdall Redial ConfList Join RmLstC Login
softkeys seized  Callback Cfwdall Endcall Gpickup HLog Meetme Pickup Redial
softkeys connected  Hold Endcall Trnsfer Park TrnsfVM Confrn ConfList Select Join Acct LiveRcd Flash
ephone-template  2
url services 2 http://phone-xml.berbee.com/menu.xml TEST
ephone-template  3
softkeys idle  Dnd Newcall Gpickup Pickup Cfwdall Redial Login
softkeys connected  Hold Endcall Trnsfer Park TrnsfVM Confrn ConfList Join
ephone-template  4
softkeys seized  Meetme Gpickup Pickup Redial
softkeys connected  Hold Trnsfer Park LiveRcd Endcall Confrn ConfList Select Join Acct
ephone-dn  1  dual-line
number 100 no-reg primary
pickup-group 1
label xxxxx xxxxx
name Reception
call-forward noan 999 timeout 40
huntstop channel
no huntstop
ephone-dn  2  dual-line
pickup-group 1
label xxxxx xxxxx
name Reception2
preference 1
huntstop channel
no huntstop
ephone-dn  3  dual-line
pickup-group 1
label xxxxx xxxxx
name Reception3
preference 2
huntstop channel
no huntstop
ephone-dn  4  dual-line
pickup-group 1
label xxxxx xxxxx
name Reception4
preference 3
call-forward busy 999
huntstop channel
ephone-dn  9  dual-line
number 130 secondary 617xxxxxxxx no-reg both
pickup-group 1
label Private Line (07 xxxx xxxx)
description 07 xxxx xxxx
name Skype1
ephone-dn  10  dual-line
number 101 no-reg primary
pickup-group 1
label Ben xxxxxx (101)
description Extension 101
name Ben xxxxxx
call-forward noan 999 timeout 25
ephone-dn  11  dual-line
number 102 no-reg primary
pickup-group 1
label Drew xxxxx (102)
description Extension 102
name Drew xxxxx
ephone-dn  12  dual-line
number 103 no-reg primary
pickup-group 1
label xxxxx xxxxxx (103)
description Extension 103
name xxxxx xxxxxx
ephone-dn  13  dual-line
number 104 no-reg primary
pickup-group 1
label Dennis xxxxx (104)
description Extension 104
name Dennis xxxxx
ephone-dn  14  dual-line
number 105 no-reg primary
pickup-group 1
label Meeting Room (105)
description Extension 105
name Meeting Room
ephone-dn  15  dual-line
number 106 no-reg primary
pickup-group 1
label Front Desk
description Extension 106
name Front Desk
call-forward busy 100
call-forward noan 100 timeout 45
ephone-dn  16  dual-line
number 107 no-reg primary
pickup-group 1
label Server
description Extension 107
name Server
ephone-dn  19  dual-line
number 119 no-reg primary
pickup-group 1
label Cordless
description Extension 119
name Cordless
call-forward noan 100 timeout 30
ephone-dn  20  dual-line
number 121 no-reg primary
pickup-group 1
label Front Reception
description Extension 121
name Front Reception
ephone-dn  21  dual-line
number 120 no-reg primary
pickup-group 1
label Conference Phone
description Extension 120
name Conference Phone
ephone-dn  22  dual-line
number 122 no-reg primary
pickup-group 1
label Reception
description Extension 122
name Reception
ephone-dn  25  dual-line
number 126 no-reg primary
pickup-group 1
label xxxxxx SoftPhone
description Extension 126
name SoftPhone1
ephone-dn  51
number 151 no-reg primary
label Line-1(5288)-Monitor ONLY
trunk 1 monitor-port 0/2/0
ephone-dn  52
number 152 no-reg primary
label Line-2(5232)-Monitor ONLY
trunk 1 monitor-port 0/2/1
ephone-dn  53
number 153 no-reg primary
label Line-3(5404)-Monitor ONLY
trunk 1 monitor-port 0/2/2
ephone-dn  98
number 998 no-reg primary
call-forward all 999
ephone  1
device-security-mode none
video
mac-address 0018.73E2.34D9
ephone-template 1
username "user1" password xxxxxx
paging-dn 32
type 7970 addon 1 7914
button  1o1,2,3,4 2:51 3:52 4:53
button  5:54 6m90 7m91 8m92
button  9w10 10w11 11w12 12w13
button  13w14 16:41 17:43 18:45
ephone  2
video
mac-address 000A.B84C.483F
ephone-template 1
username "user2" password xxxxxx
paging-dn 32
type 7970
button  1:10 2:9 3:42 4m90
button  5m91
ephone  3
video
mac-address 0019.2FE3.95A1
ephone-template 1
username "user3" password xxxxxx
fastdial 1 00413093639 name Catherine
fastdial 2 00432030586 name Ben
paging-dn 32
type 7970
button  1:11 3w10 4w13 5m90
button  6m91 7:46
ephone  4
video
mac-address 0019.2FE3.94F6
ephone-template 1
username "user4" password xxxxxx
speed-dial 1 00408760740 label "IT Support"
paging-dn 32
type 7970 addon 1 7914 2 7914
button  1:12 2:9 3o1,2,3,4 9:51
button  10:52 11:53 12:54 15m90
button  16m91 17m92 23:41 24:43
button  25:45 29w10 30w11 31w13
button  32w14 33w22 34w19 35:21
ephone  5
mac-address 0019.2FB9.CA32
ephone-template 1
username "user5"
paging-dn 32
type 7970
button  1:13 2:44 3m90 4m91
ephone  6
mac-address 000A.B84C.4598
ephone-template 1
username "user6"
paging-dn 32
type 7970
button  1:14 2m90
ephone  7
mac-address 0018.73E2.369B
ephone-template 1
username "user7"
paging-dn 32
type 7970
button  1o1,2,3,4 2:22
ephone  8
mac-address 0015.5832.54A3
ephone-template 2
type CIPC
button  1:25 2m1
line con 0
exec-timeout 0 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
exec-timeout 0 0
password
transport input all
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server 150.101.221.106
webvpn gateway gateway_1
ip address 10.0.0.15 port 443
http-redirect port 80
ssl trustpoint TP-self-signed-1560239260
inservice
webvpn install svc flash:/webvpn/anyconnect-win-3.0.3054-k9.pkg sequence 1
end
Jun  5 00:28:44.922: TFTP: Looking for term70.default.loads
Jun  5 00:28:44.922: TFTP: Opened flash:term70.default.loads, fd 2, size 660 for process 314
Jun  5 00:28:44.930: TFTP: Finished flash:term70.default.loads, time 00:00:00 for process 314
Jun  5 00:28:46.054: TFTP: Looking for jar70sccp.9-0-3TH1-22.sbn
Jun  5 00:28:46.058: TFTP: Opened flash:jar70sccp.9-0-3TH1-22.sbn, fd 2, size 1828680 for process 314
Jun  5 00:28:52.018: TFTP: Finished flash:jar70sccp.9-0-3TH1-22.sbn, time 00:00:05 for process 314
Jun  5 00:28:57.490: TFTP: Looking for cnu70.9-0-3TH1-22.sbn
Jun  5 00:28:57.490: TFTP: Opened flash:cnu70.9-0-3TH1-22.sbn, fd 2, size 506761 for process 314
Jun  5 00:28:59.134: TFTP: Finished flash:cnu70.9-0-3TH1-22.sbn, time 00:00:01 for process 314
Jun  5 00:29:01.242: TFTP: Looking for apps70.9-0-3TH1-22.sbn
Jun  5 00:29:01.246: TFTP: Opened flash:apps70.9-0-3TH1-22.sbn, fd 2, size 3084262 for process 314
Jun  5 00:29:07.243: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-7:SEP001873E2369B IP:10.0.0.204 Socket:11 DeviceType:Phone has unregistered abnormally.
Jun  5 00:29:11.219: TFTP: Finished flash:apps70.9-0-3TH1-22.sbn, time 00:00:09 for process 314
Jun  5 00:29:19.791: TFTP: Looking for dsp70.9-0-3TH1-22.sbn
Jun  5 00:29:19.791: TFTP: Opened flash:dsp70.9-0-3TH1-22.sbn, fd 2, size 540433 for process 314
Jun  5 00:29:21.559: TFTP: Finished flash:dsp70.9-0-3TH1-22.sbn, time 00:00:01 for process 314
Jun  5 00:29:23.619: TFTP: Looking for cvm70sccp.9-0-3TH1-22.sbn
Jun  5 00:29:23.623: TFTP: Opened flash:cvm70sccp.9-0-3TH1-22.sbn, fd 2, size 2166976 for process 314
Jun  5 00:29:30.807: TFTP: Finished flash:cvm70sccp.9-0-3TH1-22.sbn, time 00:00:07 for process 314
Jun  5 00:31:07.536: TFTP: Looking for CTLSEP001873E2369B.tlv
Jun  5 00:31:07.636: TFTP: Looking for ITLSEP001873E2369B.tlv
Jun  5 00:31:07.748: TFTP: Looking for ITLFile.tlv
Jun  5 00:31:08.004: TFTP: Looking for SEP001873E2369B.cnf.xml
Jun  5 00:31:08.004: TFTP: Opened system:/its/vrf1/SEP001873E2369B.cnf.xml, fd 2, size 1543 for process 314
Jun  5 00:31:08.012: TFTP: Finished system:/its/vrf1/SEP001873E2369B.cnf.xml, time 00:00:00 for process 314
Jun  5 00:31:14.424: TFTP: Looking for English_United_States/td-sccp.jar
Jun  5 00:31:14.428: TFTP: Opened flash:English_United_States/td-sccp.jar, fd 2, size 67385 for process 314
Jun  5 00:31:14.756: TFTP: Finished flash:English_United_States/td-sccp.jar, time 00:00:00 for process 314
Jun  5 00:31:15.480: TFTP: Looking for United_States/g3-tones.xml
Jun  5 00:31:15.480: TFTP: Opened flash:United_States/g3-tones.xml, fd 2, size 1036 for process 314
Jun  5 00:31:15.488: TFTP: Finished flash:United_States/g3-tones.xml, time 00:00:00 for process 314
Jun  5 00:31:31.604: %IPPHONE-6-REG_ALARM: 25: Name=SEP001873E2369B Load= term70.default Last=Initialized
Jun  5 00:31:31.652: %IPPHONE-6-REGISTER: ephone-7:SEP001873E2369B IP:10.0.0.204 Socket:11 DeviceType:Phone has registered.
Jun  5 00:31:33.228: %IPPHONE-6-UNREGISTER_NORMAL: ephone-7:SEP001873E2369B IP:10.0.0.204 Socket:11 DeviceType:Phone has unregistered normally.
Jun  5 00:32:34.333: TFTP: Looking for CTLSEP001873E2369B.tlv
Jun  5 00:32:34.413: TFTP: Looking for ITLSEP001873E2369B.tlv
Jun  5 00:32:34.521: TFTP: Looking for ITLFile.tlv
Jun  5 00:32:34.853: TFTP: Looking for SEP001873E2369B.cnf.xml
Jun  5 00:32:34.853: TFTP: Opened system:/its/vrf1/SEP001873E2369B.cnf.xml, fd 2, size 1543 for process 314
Jun  5 00:32:34.861: TFTP: Finished system:/its/vrf1/SEP001873E2369B.cnf.xml, time 00:00:00 for process 314
Jun  5 00:32:39.861: %IPPHONE-6-REG_ALARM: 25: Name=SEP001873E2369B Load= term70.default Last=Initialized
Jun  5 00:32:39.905: %IPPHONE-6-REGISTER: ephone-7:SEP001873E2369B IP:10.0.0.204 Socket:13 DeviceType:Phone has registered.
OLSENCISCO#
ephone-1[0] Mac:0018.73E2.34D9 TCP socket:[17] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 19/17 max_streams=5
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:8
IP:10.0.0.221 * 52191 7970  sub=1 keepalive 2082 max_line 22 available_line 22
Phone reports 22 Available Lines
button 1: cw:1 ccw:(0 0)
  dn 1  number 100 CH1   IDLE         CH2   IDLE         overlay shared
button 2: cw:1 ccw:(0)
  dn 51 number 151 CH1   IDLE         shared
button 3: cw:1 ccw:(0)
  dn 52 number 152 CH1   IDLE         shared
button 4: cw:1 ccw:(0)
  dn 53 number 153 CH1   IDLE         shared
button 5: cw:1 ccw:(0)
  dn 54 number 154 CH1   IDLE         shared with monitor-ring
button 6: cw:1 ccw:(0)
  dn 90 number 300 CH1   IDLE         monitor-ring shared
button 7: cw:1 ccw:(0)
  dn 91 number 301 CH1   IDLE         monitor-ring shared
button 8: cw:1 ccw:(0)
  dn 92 number 302 CH1   IDLE         monitor-ring shared
button 9: cw:1 ccw:(0 0)
  dn 10 number 101 CH1   IDLE         CH2   IDLE         watch(BLF on phone 2) shared with monitor-ring
button 10: cw:1 ccw:(0 0)
  dn 11 number 102 CH1   IDLE         CH2   IDLE         watch(BLF on phone 3) shared with monitor-ring
button 11: cw:1 ccw:(0 0)
  dn 12 number 103 CH1   IDLE         CH2   IDLE         watch(BLF on phone 4) shared
button 12: cw:1 ccw:(0 0)
  dn 13 number 104 CH1   IDLE         CH2   IDLE         watch(BLF on phone 5) shared with monitor-ring
button 13: cw:1 ccw:(0 0)
  dn 14 number 105 CH1   IDLE         CH2   IDLE         watch(BLF on phone 6) shared with monitor-ring
button 16: cw:1 ccw:(0)
  dn 41 number A501  auto dial A502 CH1   IDLE         shared with monitor-ring
button 17: cw:1 ccw:(0)
  dn 43 number A503  auto dial A504 CH1   IDLE         shared with monitor-ring
button 18: cw:1 ccw:(0)
  dn 45 number A505  auto dial A506 CH1   IDLE         shared with monitor-ring
FXO Port Monitoring Status
button: 2 dn: 51 FXO Port: 0/2/0 Status: Idle
button: 3 dn: 52 FXO Port: 0/2/1 Status: Idle
button: 4 dn: 53 FXO Port: 0/2/2 Status: Idle
button: 5 dn: 54 FXO Port: 0/2/3 Status: Idle
overlay 1: 1(100) 2(100) 3(100) 4(100)
paging-dn 32
Preferred Codec: g711ulaw
Lpcor Type: none Username: user1 Password:xxxxxxxx
ephone-2[1] Mac:000A.B84C.483F TCP socket:[15] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 19/17 max_streams=5
IP:10.0.0.216 * 52908 7970  keepalive 2081 max_line 8 available_line 8
  dn 10 number 101 CH1   IDLE         CH2   IDLE         shared with monitor-ring
button 2: cw:1 ccw:(0 0)
  dn 9  number 130 CH1   IDLE         CH2   IDLE         shared
  dn 42 number A502  auto dial A501 CH1   IDLE
paging-dn 32
Lpcor Type: none Username: user2 Password: xxxxxxxx
ephone-3[2] Mac:0019.2FE3.95A1 TCP socket:[16] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 19/17 max_streams=5
IP:10.0.0.223 * 49428 7970  keepalive 2069 max_line 8 available_line 8
  dn 11 number 102 CH1   IDLE         CH2   IDLE         shared with monitor-ring
button 3: cw:1 ccw:(0 0)
button 4: cw:1 ccw:(0 0)
  dn 46 number A506  auto dial A505 CH1   IDLE
paging-dn 32
Lpcor Type: none Username: user3 Password: xxxxxxxx
ephone-4[3] Mac:0019.2FE3.94F6 TCP socket:[19] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 19/17 max_streams=5
IP:10.0.0.201 * 52711 7970  sub=2 keepalive 2050 max_line 36 available_line 35
Phone reports 35 Available Lines
  dn 12 number 103 CH1   IDLE         CH2   IDLE         shared
button 9: cw:1 ccw:(0)
button 10: cw:1 ccw:(0)
button 11: cw:1 ccw:(0)
button 12: cw:1 ccw:(0)
button 15: cw:1 ccw:(0)
button 23: cw:1 ccw:(0)
button 24: cw:1 ccw:(0)
button 25: cw:1 ccw:(0)
button 29: cw:1 ccw:(0 0)
button 30: cw:1 ccw:(0 0)
button 31: cw:1 ccw:(0 0)
button 32: cw:1 ccw:(0 0)
button 34: cw:1 ccw:(0 0)
  dn 19 number 119 CH1   IDLE         CH2   IDLE         watch(BLF on phone 16) shared with monitor-ring
button 35: cw:1 ccw:(0 0)
  dn 21 number 120 CH1   IDLE         CH2   IDLE         shared with monitor-ring
button: 9 dn: 51 FXO Port: 0/2/0 Status: Idle
button: 10 dn: 52 FXO Port: 0/2/1 Status: Idle
button: 11 dn: 53 FXO Port: 0/2/2 Status: Idle
button: 12 dn: 54 FXO Port: 0/2/3 Status: Idle
overlay 3: 1(100) 2(100) 3(100) 4(100)
speed dial 1:00408760740 IT Support
paging-dn 32
Lpcor Type: none Username: user4 Password: xxxxxxxx
ephone-5[4] Mac:0019.2FB9.CA32 TCP socket:[14] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 19/17 max_streams=5
IP:10.0.0.222 * 51034 7970  keepalive 2129 max_line 8 available_line 8
  dn 13 number 104 CH1   IDLE         CH2   IDLE         shared with monitor-ring
  dn 44 number A504  auto dial A503 CH1   IDLE
paging-dn 32
Lpcor Type: none Username: user5
ephone-6[5] Mac:000A.B84C.4598 TCP socket:[5] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 19/17 max_streams=5
IP:10.0.0.219 * 49291 7970  keepalive 2135 max_line 8 available_line 8
  dn 14 number 105 CH1   IDLE         CH2   IDLE         shared with monitor-ring
paging-dn 32
Lpcor Type: none Username: user6
ephone-7[6] Mac:0018.73E2.369B TCP socket:[13] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 19/17 max_streams=5
IP:10.0.0.204 * 50084 7970  keepalive 100 max_line 8 available_line 8
  dn 22 number 122 CH1   IDLE         CH2   IDLE         shared with monitor-ring
paging-dn 32
Lpcor Type: none Username: user7
ephone-11[10] Mac:001F.CA35.5721 TCP socket:[9] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 19/17 max_streams=5
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:9
IP:10.0.0.77 * 53104 7965  keepalive 1214 max_line 6 available_line 6
  dn 27 number 128 CH1   IDLE         CH2   IDLE
button: 3 dn: 51 FXO Port: 0/2/0 Status: Idle
button: 4 dn: 52 FXO Port: 0/2/1 Status: Idle
button: 5 dn: 53 FXO Port: 0/2/2 Status: Idle
overlay 2: 1(100) 2(100) 3(100)
paging-dn 32
Lpcor Type: none Username: user11 Password: xxxxxxxx
ephone-13[12] Mac:000D.BCE9.7533 TCP socket:[1] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 11/9 max_streams=0
IP:10.0.0.235 * 50792 Telecaster 7940  keepalive 2143 max_line 2 available_line 2
  dn 15 number 106 CH1   IDLE         CH2   IDLE
overlay 2: 1(100) 2(100) 3(100) 4(100)
paging-dn 32
Lpcor Type: none Username: user13 Password: xxxxxxxx
ephone-15[14] Mac:0014.6A87.716A TCP socket:[2] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 11/9 max_streams=1
IP:10.0.0.236 * 50649 Telecaster 7940  keepalive 2142 max_line 2 available_line 2
  dn 16 number 107 CH1   IDLE         CH2   IDLE
paging-dn 32
Lpcor Type: none
ephone-16[15] Mac:0019.55EC.B6FF TCP socket:[7] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 1/1 max_streams=0
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:7
IP:10.0.0.185 * 10664 ATA Phone  keepalive 2139 max_line 1 available_line 0
  dn 19 number 119 CH1   IDLE         CH2   IDLE         shared with monitor-ring
Lpcor Type: none Username: user16 Password: xxxxxxxx
ephone-17[16] Mac:1955.ECB6.FF01 TCP socket:[6] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 1/1 max_streams=0
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:3
IP:10.0.0.185 * 10663 ATA Phone  keepalive 2139 max_line 1 available_line 0
  dn 2  number 100 CH1   IDLE         CH2   IDLE         shared
Lpcor Type: none
ephone-18[17] Mac:001B.2AC6.BE43 TCP socket:[3] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 11/9 max_streams=0
IP:10.0.0.77 * 51863 Telecaster 7940  keepalive 1232 max_line 2 available_line 2
  dn 28 number 129 CH1   IDLE         CH2   IDLE
  dn 12 number 103 CH1   IDLE         CH2   IDLE         silent-ring shared
paging-dn 32
Lpcor Type: none
ephone-19[18] Mac:0004.F2E2.43E0 TCP socket:[8] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 4/3 max_streams=0
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:4
IP:10.0.0.215 * 1038 7936  keepalive 2567 max_line 1 available_line 0
Lpcor Type: none
