09-04-2012 08:42 AM - edited 03-21-2019 09:51 AM
The challenge we face is that a customer needs to have buttons that both monitor their users' extensions and act as intercom buttons at the same time. So I created the intercom DNs like this:
ephone-dn 10
number 270
label User 1 Intercom
intercom 800 no-mute
ephone-dn 11
number 271
label User 2 Intercom
intercom 801 no-mute
And then I attached them to the phones via an overlay on button 1 and then monitored another intercom line from button 2 like this:
ephone 1
device-security-mode none
description User 1
mac-address xxxx.xxxx.xxxx
max-calls-per-button 3
busy-trigger-per-button 2
type 8945
button 1o1,10 2m11
ephone 2
description User 2
type 7975
button 1o2,11 2m10
Button 2 calls the other phone's intercom line just fine, however when the phone is in use the button does not light up. So I changed button 2 to be a watch button instead of a monitor button:
ephone 1
button 1o1,10 2w11
ephone 2
button 1o2,11 2w10
Button 2 still calls the other phone's intercom line just fine, but now the light is always lit on each phone regardless if the phone is in use or not. This seems to be a bug, but I wanted to put it out there to see if anyone had any suggestions. Using IOS 15.2(2)T (which uses CME 9.0) on a 2921.
Thanks!
09-04-2012 10:20 AM
You cannot have a button that is both a DN, (intercom or not), and monitor.
09-04-2012 01:02 PM
I want to make sure I understand you, because by what you are saying sounds like I am trying to overlay a DN and a monitor button which is not what I'm trying to do.
Button 1 is an overlay with the user's normal extension and the user's intercom extension. Button 2 is NOT overlayed and is a monitor or watch button. I have done this in the past with non-intercom DNs without a problem.
Thanks for your time.
09-04-2012 10:57 PM
I'm not talking abot overlay.
I'm saying you cannot have a smae button that is associated to a DN on which you make and receive calls, and also have it montor another DN, or device. You will need two buttons for this purpose.
09-05-2012 06:15 AM
I'm not doing that either. The button that we are trying to monitor from is button 2 and it's only purpose is to monitor another line (or watch another phone).
button 1o1,10 2m11
or
button 1o1,10 2w11
Thank you for your assistance!
09-05-2012 07:09 AM
But you're trying to watch or montor an overlaid DN.
try
blf-speed-dial xxx name "zzz" device
09-13-2012 07:41 AM
The blf-speed-dial command works fine as a speeddial to the intercom line, but it will not light up when the phone is in use. I even tried seperating the intercom DN from button 1 and putting it on a secondary button and that doesn't work either.
I don't think there is a way to have a button call an intercom dn and have that same button light up when the remote phone is in use.
Thanks for your help.
09-13-2012 09:28 AM
What is the icon close to the label? If only a keypad, then allow-watch and/or presence are not configured.
It must be a small phone over a keypad for monitoring to work.
10-01-2012 10:53 AM
The icon is a phone with the lines coming out from the left of the phone. When I do "show presence subscription summary" I get the following output showing an "unknown" status:
2921#show presence subscription summary
Presence Active Subscription Records Summary: 53 subscription
D indicate as device-based blf-speed-dial monitoring
Watcher Presentity SubID Expires SibID Status
D 210@10.0.2.107 271@10.0.2.1 108849 3600 0 unknown
If I change the BLF to watch a non-intercom DN on that same phone then the status shows "idle" instead of "unknown" and the icon is a phone over a keypad. It just seems that BLF won't work on an intercom DN.
Here is the relevant portion of the config. Ephone 2 is trying to monitor button 2 on ephone 1 and it doesn't work. If I change it to monitor button 1 (which is a normal DN) it works fine.
presence
presence call-list
watcher all
allow subscribe
sip-ua
presence enable
!ephone-dn 2 dual-line
number 211
cti watch
allow watch
call-forward busy 600
call-forward noan 600 timeout 20
mwi sip
!ephone-dn 3
number 271
label Intercom
allow watch
!ephone 1
ephone-template 10
presence call-list
type 7975
button 1:2 2:3
!ephone 2
presence call-list
blf-speed-dial 1 271 label "Intercom" device
type 8945
button 1:1
Thank you for your help.
10-01-2012 01:32 PM
I just discovered that if I put the intercom button on line 1 as the primary line that the blf-speed-dial works with an intercom DN.
From the manual for blf-speed-dial:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_b1ht.html#wp1049326
This command enables a phone to monitor the status of a line associated with a speed-dial button. The "device" keyword enables BLF monitoring of the phone for which the watched directory number is the primary line. This allows watchers to monitor whether a user is on the phone, not just on an individual line on the phone.
The problem with this however is that I need the primary line for the users' normal extension and not a speed dial button. I tried to overlay underneath the intercom DN the normal extension and the BLF still works, however when you pick up the phone it calls the intercom speed dial.
Any other ideas? Thank you!
------------ Update-----------
This is also the case for a watch button. Watch only works on the primary line. If the number you are monitoring is not the primary line then the button will always show as off-hook on the watching phone.
