What extensions can be used for phones
lbroering
We are deploying a UC560 with 31 phones and are using the default extension pattern below -
Default Leading digits
1xx – Page Groups
2xx – Extensions
3xx – Voice Mail and Auto Attendant
4xx – Night Service codes
5xx – hunt groups
6xx – not used
7xx – Park Slots & MM Conf extensions
8 – Intersite dialing access
9 – Public access
Would there be a problem with assigning several phones with extension numbers that are not in the 2xx range? Some users are in a different business and want to have extensions that start with someting other than 2. For example, could 5 of the phones be extensions 350 to 355 or 450 to 455?
paolo bevilacqua
Yes, absolutely. The above is just a reasonable recommendation particularly applicable to North America.
paolo bevilacqua
mcasimirc63
Level 4
Level 4
I probably should been more specific on the spreadsheet,
The leading digits listed are built into CCA by default or are  typical deployment configurations. The  digits can be changed at any point but leaving them at default is recommended  for simplicity in configuring CCA
101 - 110 – Page Groups
2xx –User Extensions
399, 398, 397 – Voice Mail, Auto Attendant and Prompt Manager
*299 – Night Service code
501 - 510 – Hunt groups
511 - 520  – Blast Groups
6xx – not used
701 - 710, 771 - 802 – Park Slots & Meet-Me Conference extensions
8+1-5 – Intersite dialing access
9 – Public access
Thanks Everybody!
Thanks for the nice rating and good luck!
