Showing results forĀ
Search instead forĀ
Did you mean:Ā
XML Config for Fido Telecom / Fido Talk
jon
Hi ,, hope this is the right place
Can you generate an XML config for Fido Talk (UK ITSP / VoIP operator) and maybe include it in the next UC update?
Name of ITSP  FidoTelecom
Dialplan locale UK
Display Proxy Server (Primary) sip.fidotalk.co.uk
Display Proxy Server (Backup) sip.fido.net
Display Registrar Server field Yes
Display Outbound Proxy Server field No
Display Digest Authentication (Username / Password) Yes
Display Customer Company Name field No (optional)  Yes
Display Call Admission Control field No (optional) No
Display User Credentials field No (optional) choose No
ITSP SIP TRUNK PARAMETERS
Voice Codec G.711ulaw
Fax protocol T.38
RFC2833 (DTMF) payload type 101
Should UC500 register all DIDs to ITSP No
Is SIP registration for DID(s) using same username / password or unique username / password per DID NA
Many Thanks
Alberto Montilla
Dear Sir;
Can you please get it contact with your Cisco Account Manager, so that he directs the request on your behalf. For security reasons, we need a local Cisco AM to handle the request first.
If you don't have a Cisco AM, I suggest you contact John Smith (josmith) or James Pearce (jampearc) at cisco.com. After that I'll be more than happy to handle the request.
Regards;
Alberto
