2 way Paging UC500
cachorropr
Beginner
Beginner
K12 school is upgrading the PBX and we are implementing UC500 series for 30 endpoints. School also has 30 2 way legacy intercom system that they want to integrate with the PBX. Since UC500 doesnt support SIP, anybody know of a 3rd party that would do this? I cant do it with FXS ports since there are so many 2 way intercoms and it would be nice to do it SIP based.
I could go with BE6000 or CME but the price difference would scare away this customer.
Any ideas?
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
UC500 perfectly supports SIP, you just have to configure it.
I was under the impression that UC500 could only use SCCP endpoints and SIP was just supported for trunking. Has anybody used the Cyberdata/Valcom 2 way intercom units with UC500?
Trunk or endpoint, anything SIP works.
Thank you for the nice rating and good luck!
Thanks for reply, I'll try it out.
