3rd Party Sip Client Registration on UC540
sanjay.khurana
Beginner
Beginner
Hi ,
I have Cisco UC540 box and this is working fine between office , now this time I want to setup 3rd party SIP client phone , e.g. 3cx sip client..
I have configured following configuration into box which I got from google , as I don't have good knowledge of voice configuration . I am Data network guy.
voice register global
mode cme
source-address 192.168.76.10 port 5060
max-dn 4
max-pool 4
authenticate register
create profile sync CF281E9C1D6C0F1A
voice register dn  1
number 2020
name Sanjay Phone
label 2020
voice register pool  1
id mac 7CC3.A1A1.EF11
number 1 dn 1
dtmf-relay rtp-nte
username siptest password siptestpw
no vad
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
voice-class codec 1
voice service voip
allow-connections sip to sip
sip
registrar server
After Putting above configuration I am not able to register SIP client , and getting following logs.
000641: Aug 31 13:11:45.406: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.76.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.12.100:52171;branch=z9hG4bK-d8754z-8c70b6132070ea23-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:2020@192.168.12.100:52171;rinstance=90c7221d60ca88ea>
To: "2020"<sip:2020@192.168.76.10:5060>
From: "2020"<sip:2020@192.168.76.10:5060>;tag=1142a043
Call-ID: OGNlZDFkM2YxNjFiY2ExNTM4ZTQ1Y2JiM2FjMzM5M2U.
CSeq: 1 REGISTER
Expires: 240
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Supported: replaces
User-Agent: 3CXPhone 6.0.25732.0
Content-Length: 0
000642: Aug 31 13:11:45.410: //11947/3EB091A9B5F6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: "2020"<sip:2020@192.168.76.10:5060>;tag=263A3918-2561
Date: Fri, 31 Aug 2012 13:11:45 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 REGISTER
WWW-Authenticate: Digest realm="",nonce="8D4D37311D6C38E8",algorithm=MD5,qop="auth"
Content-Length: 0
000643: Aug 31 13:11:47.506: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 REGISTER
Expires: 240
Supported: replaces
Content-Length: 0
000644: Aug 31 13:11:47.510: //11947/3EB091A9B5F6/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 31 Aug 2012 13:11:47 GMT
CSeq: 1 REGISTER
Content-Length: 0
Please help me to understand where I am doing worng to get this done.
I am attaching UC540 box configuration for reference.
2 REPLIES 2
David Trad
Rising star
Rising star
Hi Sanjay,
Can you please change the following lines to this?
to this:
username 2020 password 123456
Just as a test and let me know how it goes, it would seem the UC does not like the registration string and I would like to see if the above changes the results
Cheers,
David Trad.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Why thirdy party softphones (or even phones) that will only produce trouble with their many limitations..
Do not pollute your industry leading voip system introducing inferior components.
If you need a sofphone, use CIPC, and everything wil work perfectly for total customer satisfaction.
