5 POTS lines
alangoh27
Is there any way to use 5 POTS lines on the UC320? What are my other options?
Alan
wenyang
Level 4
Level 4
Hi Alan,
UC320W includes 4 FXO ports and 1 FXS port. You can enable them at Configure Utility through Configure -> Line (FXO) Ports and Configure -> FXS Port. Then you can assign an analog phone to the FXS port and connect the teleco analog phone lines to FXO ports.
Hope it helps.
Best regards,
Wendy
To add to Wenjin's post, you may consider adding a SPA8800. It has 4 fxo/4fxs.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
