10-28-2009 02:38 PM - last edited on 03-25-2019 10:42 PM by ciscomoderator
When our customer uses their EditDial softkey to return a missed or received call, the cursor put them at the end of the 10 digit number string ? Most handsets have the cursor at the start of the digits so they can simply press 9 and call from there. With the cursor at the end, you have to back arrow to the beginning to add the leading 9 - what a pain !
Is there a way to adjust or modify this in the 525's settings? I cannot seem to find any info on it in the 525 manual I have...
Thank you,
Stacy
Solved! Go to Solution.
10-29-2009 01:13 AM
Just create the translation rules for this, it can not be done (Well not that i am aware of since the last answer i got) and everyone complains about it so i just gave up and create rules so that it auto inserts the number there, could never understand why this needed to be done, Cisco phone systems are the first ones i have seen where you have to manually edit the number to be able to call it back :D
Just PM me stacey if you need help with creating the Translation rules and would be more then happy to try and work with you on this.
Cheers,
David.
10-29-2009 01:13 AM
Cheers,
David.
10-29-2009 07:20 AM
Thanks David!
I'll see if the Cisco BU team has a definitive "cisco" answer....and if I hear nothing then we'll do just as you suggested- edit the trans rules to add it for them.
I'm less impressed with the 525 each day.
Stacy
11-05-2009 08:55 AM
No one else has offered any input here- 1) is this normal for a 525 ? 2) how do you fix it short of taking Davi'd suggestions ?
Thx,
Stacy
11-05-2009 08:57 AM
I will put in a request to have the edit dial changed, but it might be awhile before that gets implemented.
