I have Cisco SPA 525G2 with Software Version: 7.5.7s and Hardware Version: 2.0.0.
I use https provisioning based on periodic resync.
I found an issue with Programmable Softkeys -> Dialing Input Key List
I want to use this settings:
<Dialing_Input_Key_List group="Phone/Programmable_Softkeys">dial|1;delchr|2;clear|3;cancel|4;</Dialing_Input_Key_List>
Problem is that when I use „clear|3” I don't see the “Clear” button on screen [see a picture in attachment].
Is there any option how to use this button? I only found a possibility of the 'Option button' [option|3] but the 'Clear button' [clear|3] better fit my needs.
Do you have any experience with this issue?
The second thing which I don’t understand is that for SPA525 must be 'delete character' softkey in format “delchr” and for 504 must be in format “delchar”. [but i can deal with it].
Best regards,
Jakub Zima
