A reviewer on Amazon stated the following:
" In theory the 320w can support both SIP and analog lines, with one big limitation. BOTH SIP AND ANALOG LINES MUST SUPPORT 10 DIGIT DIALING, EVEN FOR LOCAL CALLS. Analog and SIP lines must use the same dial plan! AT&T POTS lines do not support 10 digit dialing of local numbers, SIP providers require ten digits. Hence I can't add SIP lines unless I replace all our POTS lines."
Is this true? My concern is that in our location, the analog lines use 7 digit dialing. This could be a show stopper if true.
