11-10-2012 12:41 PM - edited 03-21-2019 06:35 AM
I have the Cisco 7921g wifi phone which is really cool works really well on Wifi with the UC500. I notice it talks about USB, and when I connect it to my Mac it appears as a network interface. Tried scanning the manual, but just wanted to clarify there's no way to use this phone remotely as a soft phone if connected to VPN is there? Like not with wifi, but like if I connect on my Mac using IPSec VPN or on Windows, I can't connect this phone to my PC and use it as a soft phone instead of IP Communicator can I?
Solved! Go to Solution.
11-10-2012 12:44 PM
No. Cisco wireless phones use USB for configuration only, and it's even possible to avoid using it altogether.
All voice connectivity happens over WLAN.
11-10-2012 12:44 PM
11-10-2012 02:27 PM
That's what I figured but thought I'd check as that would have been handy instead of using the communicator.
