10-12-2012 04:32 AM - edited 03-21-2019 06:25 AM
I was using cisco unified configuration on uc 500 and deleted extention while phone was plugedin
Now the phone does not connect and says registration failed
What should i do i am in big problem it was my boss extention
I did same misstake with 7975 also
Kindly help
Its urgent
10-12-2012 07:01 PM
If you didn't save the config just reload and the original startup-config will load. Be sure not to save if asked.
10-13-2012 12:53 AM
I have saved the new config what now?
