Showing results forĀ
Search instead forĀ
Did you mean:Ā
a problem with pickup in module expasion SPA500S
Julio Saldivar
I have a problem with the phone 502 and the module expansion SPA500S, these are registered to a SIP server in the  UDP port 5080 , everything works fine, unless pickup from the module expansion. when i check  the SIP packets, to perform the pickup send packet to port 5060 and not to port 5080.
configuration
proxy=10.0.10.1:5080
fnc=sd+cp+blf;sub=582@$PROXY
nseto
Level 6
Level 6
Instead of $PROXY, try making it explicit.  Put 10.0.10.1:5080 instead.
